timing belt keeps breaking???
Old Oct 21, 2002 | 07:56 PM
stupidfast's Avatar
Default timing belt keeps breaking???
My timing belt has broken twice in the past 5000 miles.. what the hell could be causing this.. I had honda replace it both times.. Could it be cam gears?? Im running hayame cam gears right now, i dont know if that is whats causing it but i dont know what else it could be.. Please some one give me some suggestions...
Old Oct 21, 2002 | 08:01 PM
PhatOptimo's Avatar
Default Re: timing belt keeps breaking??? (stupidfast69)
Did you ask them if the found anything in there. I've had my inner cover bolt come loose and shread my t-belt. Also are you running it with open covers? Most of the times its a foreign object if the belts relatively new.
Old Oct 21, 2002 | 08:03 PM
stupidfast's Avatar
Default Re: timing belt keeps breaking??? (Phat_Optimo)
yeah i run it open.. but do you think thats the problem???
Old Oct 21, 2002 | 08:07 PM
saso
Guest
Posts: n/a
That is the problem, the stones get between the belt and the timing gear and cause premature wear. Put back on the cover or fabricate one.
Old Oct 21, 2002 | 08:14 PM
PhatOptimo's Avatar
Default Re: timing belt keeps breaking??? (saso)
Yep, put the covers back on.
Old Oct 21, 2002 | 08:40 PM
FitCRX's Avatar
speaking of the cover...I have a b16a1...timeing marks are on the cover..and the engine didn't come with one...I need a cover..but which to use? 94 delsol?
Old Oct 21, 2002 | 08:49 PM
stupidfast's Avatar
Default Re: timing belt keeps breaking??? (FitCRX)
yeah!!
Old Oct 21, 2002 | 09:07 PM
FitCRX's Avatar
yeah?? yeah what??
Old Oct 21, 2002 | 11:43 PM
kinesistech's Avatar
yeah you answered your own ?
Old Oct 22, 2002 | 01:19 AM
MikeSarr_GSR's Avatar
Default Re: timing belt keeps breaking??? (kinesistech)
upgraded valvesprings with increased tension cause more force to be exerted on the belt. with a higher lift cam like you have, it increases this wear again. not having upgraded the LMAs to ITR units can also cause your valvetrain to bottom out like stock shocks on upgraded springs. I would look into TODA's timing belt or one of that nature for your application. running the upper valve cover open is OK, I have had my upper one open for months with no belt damage, keeping the bottom one in place.
Old Oct 22, 2002 | 09:52 AM
jetli6969's Avatar
New User
Default Re: timing belt keeps breaking??? (MikeSarr_GSR)
how about a power enterprise?
Old Oct 22, 2002 | 10:05 AM
Default Re: timing belt keeps breaking??? (jetli6969)
thats the money, I know Tony L runs that belt on his high hp B18C applications
Old Oct 22, 2002 | 10:34 AM
Big Phat R's Avatar
Most likely belt tensioner not adjusted correctly.
Old Oct 22, 2002 | 12:58 PM
Default Re: timing belt keeps breaking??? (Big Phat R)
I was assuming this was something that was a given, that too is a possibility. anything rubber can eventually snap...
PandaBear
Feb 24, 2006 10:00 PM
oes
Mar 10, 2004 10:23 PM
RacerZook
Jan 6, 2004 12:54 AM
RacerZook
Jan 5, 2004 07:36 PM
Jonathan_ED3
Jun 21, 2003 08:27 PM
