Compression test results help!
Old Mar 8, 2013 | 06:25 AM
delsolo95's Avatar
Default Compression test results help!
ok ive rented the oem brand compression tester from vatozone yesterday and conducted a compression test on my 00 gsr motor.
I removed all spark plugs, disabled fuel injectors, held the throttle wide open, and cranked until the needle stopped climbing. all cylinder were tested 2 times before i recorded the final number of psi. i put a cap full of oil into cylinder # 3 and the psi jumped up to 300 (that's the max my gauge will let it go). Also this was done on a cold engine. here are the results
cylinder 1. 221 psi
cylinder 2. 243 psi
cylinder 3. 215 psi
cylinder 4. 243 psi
what does this mean for cylinder #3? my rings are bad? my valves or valve seals, or ???
Old Mar 8, 2013 | 06:34 AM
JuggerNaut-CTR's Avatar
Default Re: Compression test results help!
Thats what a leakdown test is for...
Old Mar 8, 2013 | 06:37 AM
delsolo95's Avatar
i searched up that if psi jumps by adding oil to a cylinder it means the cylinder rings are at fault. True?
Old Mar 8, 2013 | 06:44 AM
Yes that is true...
But thats a "probably"...i would go for definate. You can add oil to the other cylinders and cause the psi to jump up as well.
When you initially removed the plug from cylinder 3, did it looked fouled at all? Was there oil on it?
Old Mar 8, 2013 | 07:19 AM
delsolo95's Avatar
1, 2 and 3 had oil on the plugs. 3 having the most on it. did not look foul as i just changed all plugs a month ago without putting a single mile on it.
i will look into buying a leak down test kit soon. thanks
Old Mar 8, 2013 | 07:27 AM
delsolo95's Avatar
zamnnn! a leak down test kit at vatozone is $150.00 wtf
Old Mar 8, 2013 | 03:43 PM
delsolo95's Avatar
well just bought a leak down test kit from summitracing for $80. ill give updates once i get it in the mail.
Old Mar 8, 2013 | 06:19 PM
jbpnoman's Avatar
Yes, leakdown kits are expensive, because they require an air compressor.
Old Mar 8, 2013 | 06:25 PM
SiRCiviC94's Avatar
the tester is worth more than your engine. if its huffin over 200 keep on bangin
Old Apr 3, 2013 | 08:49 AM
delsolo95's Avatar
well guys i got my leak test kit but still havent tried used it since. i should be able to do it this weekend though.
B16.vtec
Sep 12, 2013 06:58 AM
aznxpyroboi
Dec 9, 2007 10:09 PM
Tyteg
May 16, 2007 07:30 AM
evotux
Nov 20, 2006 07:01 PM
debogsr
Jan 9, 2006 12:35 PM
