D16Z6 - all 4 spark plugs are burnt
Old Feb 14, 2013 | 09:47 PM
Skieza's97's Avatar
Post D16Z6 - all 4 spark plugs are burnt
Ok so I bought a z6 vtec threw it in my car it was hesitating to start and then I played around with the distributor and did the timing like 4 times so I finally mess with the spark plug wires and it starts ! Car was idling super rough and it was at 3000rpms jumping up and down ! So I removed the plugs just now and all 4 are burnt ! Any ideas ?
Old Feb 14, 2013 | 09:49 PM
GoodSkoolRevltn's Avatar
Default Re: Helllllllllp!!!
this was the first one i could find, but theres tons of picture charts like these.
http://www.mudinmyblood.net/forum/im...park_plugs.jpg
Old Feb 14, 2013 | 09:50 PM
jbpnoman's Avatar
Oh wow. OP, try that again. This time, read the rules sticky, give us all necessary information (hint: what's necessary is in the rules), and try typing in comprehensible English.
Old Feb 14, 2013 | 10:04 PM
Skieza's97's Avatar
When I removed the plugs I looked in to the plug cylinders and I saw that the pistons where black ??
What u mean comprehensible English ??
Old Feb 14, 2013 | 10:09 PM
jbpnoman's Avatar
Don't use run on sentences. Don't abuse punctuation. Use easily read sentences. Don't type like you're in a chat room or texting. Type like you have a grasp of the English language greater than that of a 6 year old. It makes it a LOT easier to help you, and makes people MUCH more likely to actually want to help.
Black piston tops are normal. Post pictures of your spark plugs so we can see what you're talking about. You also still need to give us more information. What chassis do you have? What other modifications have you done? What ECU and wiring harness(es) are you using?
Old Feb 14, 2013 | 10:16 PM
Skieza's97's Avatar
Ohh okay I understand , I can't add pictures at the moment because I just started this account . My chassis is a 1997 Honda civic and I swapped my d16y7 with a d16z6 vtec engine I am currently running my non vtec ecu and the d16y7 harness. I was messing with the distributor and the spark plug wires because the car wasn't turning over , it seemed like the car wasn't getting spark after messing around with the wires It finally started but it was thumping I knew it was misfiring and the idle was going from 2500 Rpm to like about 3200rpm it was at high idle.
Old Feb 14, 2013 | 10:27 PM
i think you can add pictures but i may be mistaken. join photobucket or something or use that facebook thing everybody has now i forget what its called. or theres a site or 2 where you can free image host.
Old Feb 14, 2013 | 10:29 PM
jbpnoman's Avatar
photobucket works, although I personally like imgur.com more.
The Z6 won't just plug in. What wires did you modify? How did you modify them? What CELs are you throwing?
Old Feb 14, 2013 | 10:36 PM
Skieza's97's Avatar
Ill check that out right know. I modified the wires 1-3-4-2 then 1-4-3-2 then i modified it back to 1-3-4-2 and it started . The random cylinder misfire was on and either throttle sensor or map sensor was at a high circuit .!?
Old Feb 14, 2013 | 10:42 PM
jbpnoman's Avatar
I don't mean the spark plug wires. There are only a million different pictures and descriptions of how those should be installed, I'm not going over it again. I'm talking about your wiring harness. Most of the sensors won't just plug in. The Z6 is an OBD1 motor, whereas your car is OBD2A.
Old Feb 14, 2013 | 10:47 PM
skieza97's Avatar
Oh ok sorry about that. Well it is wierd that there obd1 and obd2 but all the plugs fit not one was changed or modified they all plugged up
Old Feb 14, 2013 | 10:51 PM
jbpnoman's Avatar
Pull all of the codes and post them. You can find a DIY how-to in the FAQs sticky. Those spark plug pictures would still be useful as well.
Old Feb 14, 2013 | 10:58 PM
skieza97's Avatar
Yea ill post them tomorrow when I get the tool and I just posted the picture hope it works !
Old Feb 14, 2013 | 11:10 PM
skieza97's Avatar
Old Feb 15, 2013 | 11:59 AM
skieza97's Avatar
Ok so the code I have is P1337 manufacture control ignition system or misfire
Old Feb 15, 2013 | 12:27 PM
EM1H22A's Avatar
HELP IM A NEW MEMBER SO I CANT START NEW THREAD!!!
(sorry for posting thing in a random thread)
hey im a new memeber so i cant post a new thread until 15 days, can you help me with urgent info or guide me a thread witch can help me?
i basicly have an h22a in a 97 ek hatch, im currently swapping the h in a em1 99 si. everything is going good but im just wondering if i could keep the 99 wire harness or if i have to take my 97 harness.
please help
thank you
Old Feb 15, 2013 | 01:01 PM
jbpnoman's Avatar
Default Re: D16Z6 - all 4 spark plugs are burnt
And that's the only code, skieza? Also, picture of plugs.
EM1, you can't make a thread for a reason - you're expected to put a modicum of effort into searching. Go to the hybrid forum (it's there for a reason) and start reading.
Old Feb 17, 2013 | 11:40 PM
skieza97's Avatar
yeah the only code and it dosent seem to let me add a picture but spark plugs just look like the car is running very rich!
eortizr
Mar 30, 2019 11:43 AM
solerizr
Sep 30, 2006 11:16 PM
mikeyp5d
Nov 16, 2005 12:58 PM
ViruS05
Oct 22, 2005 10:24 AM
deacs
Oct 1, 2002 10:33 AM
