Help!!!! Overheat!!!
Old Feb 12, 2013 | 06:57 PM
shogun1552's Avatar
Default Help!!!! Overheat!!!
I have a fail safe thermostat, new water pump, new ect sensors, new radiator, and fresh coolant 50/50 mix. My compression is good on all four cylinders. No water in oil and no water in exhaust. I have filled the entire coolant system several times and every time I drive the car over 30 minutes, the temperature climbs to hot and drops to normal. Sometimes when it is hot, fan is not coming on and I have tested it for motor operation. Sometimes when it is hot, if I let off of accelator, temperature drops or if I accelerate slightly, the temperature drops to normal. If I kick v-tech in, temperature climbs faster to the H. Today, I refilled coolant and even though, I do not have a bleeder valve, I left the heater hose off that goes to the thermostat housing and only filled it up until coolant ran out of it. I started the car up and used a spill free funnel so it would fill up with coolant. After running a while at 2500 rpm, fan came on once and went off, gauge temp showed half way and I had a cooking thermometer in the funnel of coolant and it read up to 215 degrees and fan was not on at this point. However, the inside gauge showed only half way. So please help on this matter or give me some good ways of getting all air bubbles out of the system. FYI When I fill coolant, car is on ramps with the front raised up. Heater is on high and I fill the radiator until it will not hold anymore. I start the car and let the fans come on twice and check the coolant. I called a Honda dealer and talked to a service manager and he told me that is a nightmare to get the air bubbles out a bleederless system such as my motor (D16Y8). Any suggestions would be very helpful!!! Forgot to mention, heater is intermittently blowing hot to cold air.
Old Feb 12, 2013 | 07:15 PM
fonkernuckle's Avatar
Default Re: Help!!!! Overheat!!!
Question that comes to mind is: did you change all the components mentioned to try to solve the overheat problem? Or did the overheat problem begin afterwards?
When you mention compression is good on all four cylinders:what are the numbers?
All air bubbles should have disappeared doing what you have done.
The only times that I have had persistent air bubbles in the neck of my radiator have been when I had blown/leaking head gaskets. A leakdown test might help diagnosis.
Wish I could be more help
Old Feb 12, 2013 | 07:38 PM
shogun1552's Avatar
Compression on 1 is 134 2 is 132 3 is 135 4 is 134 problem started when upper radiator hose busted.
primetime
Aug 22, 2010 07:00 PM
pentaq
Sep 13, 2005 03:19 PM
jadugartir
Aug 4, 2005 12:15 PM
dkdjlf
Aug 14, 2003 10:34 AM
bigblockEG
Apr 25, 2003 04:32 PM
