92 Civic LX idle issues
Old Feb 10, 2013 | 07:00 PM
Phoenix.'s Avatar
Icon6 92 Civic LX idle issues
Hi guys well I've recently aquired a 92 Civic and since then it has had a weird idle problem. Let me explain to you, when I first turn on the car it will idle at about 1500rpm and eventually dropped down to about 500. Now the car shakes a bit but I know it won't turn off on me. But when I turn my headlights on the RPM jumps to about 900 and it feels like it runs better that way. I don't know what it could be. Have any of you guys experience something similar. What could it be IACV? Alternator? distributor?
Old Feb 10, 2013 | 07:04 PM
vartok's Avatar
Default Re: 92 Civic LX idle issues
IACV i would be my first stop. 500 is a tad low i think for an idle
Old Feb 10, 2013 | 07:09 PM
Phoenix.'s Avatar
That's what I would think too, weird thing is how the RPM goes up when the headlights are on.
Old Feb 10, 2013 | 07:16 PM
vartok's Avatar
put a slight load on the engine, causing it to idle up.. mine does that but goes from 80 to 1k then slowly backs down... but i also have HIDs
Old Feb 10, 2013 | 07:22 PM
Phoenix.'s Avatar
oh ok i see that, im not very experienced comes to when it comes to cars. Would a be hard if i tried to clean the throttle system by myself?
Old Feb 10, 2013 | 07:25 PM
19da90's Avatar
yes i had this problem to i just go my part IACV but there are 2 of them i think..
Old Feb 10, 2013 | 07:27 PM
Phoenix.'s Avatar
would your car also idle up once you turned your headlights on?
Old Feb 10, 2013 | 08:55 PM
Phoenix.'s Avatar
any other suggestions?
Old Feb 10, 2013 | 11:53 PM
G_thirty_5's Avatar
Check timing. And air.. on your throttle body has a screw.. use a flat head and tighten it shut then turn it open 3 full turns. Make sure your distributor is in the center
codizz88
10
Mar 3, 2016 04:37 PM
95civicguy12
Sep 5, 2014 04:40 PM
xxstreetracer605
11
Jun 20, 2012 11:40 AM
efyou
Apr 18, 2007 06:00 PM
clutcher
Apr 6, 2005 08:04 PM
