92 Civic VX high idle only with headlights on.
my vx idles fine nice and low until i turn on the lights and it usually idles around a 1000. I know they go into a compensated idle when the engine has a load but jumping up to 1000 is definitely too high, curious if this could be adjusted or is something faulty? thanks.
Re: 92 Civic VX high idle only with headlights on.
Nice and low as in low like a d15z1 is supposed to be. if its idling around 500-600 which is normal then jumps to 1000 with headlights on i figured it would be something other then adjusting idle speed itself otherwise i would have just went through the procedure to adjust it. Not sure if there was a voltage regulator or something alternator related that senses current to tell engine to pickup rpms to compensate.
I never narc'd on nobody!
You aren't listening to what either of us are telling you. It's a well known fact that the OEM tach, if you even have one, is horribly inaccurate. Get an external tach. Find out what your idle speed is. You might be idling too low, which could cause exactly the symptoms you're having. Do I need to spell it out more clearly for you, or are you going to listen to advice given now?
Except that i have, even though what was said is very little to begin with. Regardless if the ******* tach is off a little i have been around enough vehicles, motorcycles anything else with an engine to know around what rpm its at, and if the rpms damn near double instead of increasing around 100 or so for compensated idle then that is what led me to believe the possibility of it being something else...
If where your getting at is that if the idle is too low, then with a load on the engine it somehow idles higher than normal then i dont see how it was so hard to say that in the first place.
Last edited by Former User; 03-03-2016 at 04:24 PM. Reason: Insulting remarks deleted
Yeah, you really need to hook up a proper tach and post the redings Sometimes the cluster tach is just a decoration with regard to accuracy.
Please keep the discussion civil and focused on tech.
Tell that to the other guy, where the confrontation started. Start at the source, nothing civil about what he said.
No he started with an insult then i followed...are u seriously going to turn a blind eye to how this started in the first place? Thats fine close the thread im done.
live4soccer7
13
10-12-2022 02:38 AM
Jimi Hondrix
11
04-19-2016 03:44 PM
jlk16188
09-14-2013 12:45 PM
