How to Remove Broken Header Stud Bolt
Old Oct 21, 2002 | 07:25 AM
Ceeveek's Avatar
New User
Default How to Remove Broken Header Stud Bolt
hopefully i used the right name there - the bolts/studs used to keep the exhaust manifold attached firmly to the block...one of these bolts is snapped off, how should I remove this to replace it....how is it set in there block? am i going to have to drill it out? Any help would be great. Thanks
Old Oct 21, 2002 | 07:34 AM
TRENDSETTLER's Avatar
Default Re: How to Remove Broken Header Stud Bolt (Ceeveek)
i had a bold stuck in the head and this is how i got it out...after spending forever tryin to drill it out with a bold extractor we...
grabed the drimel and put a cutting bit in it
cut a slit across the bolt wide enough to fit a flathead screwdriver
used a screwdriver to unscrew the bolt
it unscrewed really easy...like i said i did this to get a screw out of the head so i dont know if you have enough room to do this for the header but its worth a shot
Old Oct 21, 2002 | 08:29 AM
Ceeveek's Avatar
New User
Default Re: How to Remove Broken Header Stud Bolt (TRENDSETTLER)
so you're saying the part of the bolt that is recessed into the head has a thread on it? it can be unscrewed?
Old Oct 21, 2002 | 08:47 AM
ananh's Avatar
it's just one bolt....who cares
Old Oct 21, 2002 | 09:11 AM
owen_the_soyboy's Avatar
yes, of course that is threaded into the head. If you can cut a notch in it do so and unscrew it. somepeople have welded a piece of metal to the broken part to unscrew it. others try to drill them out using a left hand bit. others use EASY OUT extractors, might work for you.
I left mine in there, no big problemmo
Old Jul 17, 2003 | 04:19 PM
dwnthehatch's Avatar
Default Re: How to Remove Broken Header Stud Bolt (owen_the_soyboy)
Did you ever get it out? I just pulled the heat shield off of the exhaust manfold on my gsr swap I just got from IAS and noticed two nuts were missing, one bolt was snapped and there is some sort of sealant all over the gasket. I left Larry Jr a message but I doubt he will do anything about it.
Here's some pics:
Old Jul 17, 2003 | 04:25 PM
deepgreengsr's Avatar
always have the car warmed up when doign any kind of exhasut work. espcially on cast iron. loosen them with the car running , and then shut it off and remove them. on removeing it, I usually put in a center punch on the stud. Get is centered perfect. then dril it out to the TAP size of the hole then run a tap in there. It works really well, and is pretty fast. Get a 90Deg attachemnt for your drill for a hole like that.
Old Jul 17, 2003 | 07:19 PM
Behan's Avatar
Default Re: How to Remove Broken Header Stud Bolt (deepgreengsr)
damn talk about bringing a thread back from the dead
Old Jul 17, 2003 | 08:38 PM
Stripped Honda's Avatar
99-0104
Default Re: How to Remove Broken Header Stud Bolt (dwnthehatch)
you gotta love morons that love to put silicone everywhere ......
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dwnthehatch &raquo;</TD></TR><TR><TD CLASS="quote">Did you ever get it out? I just pulled the heat shield off of the exhaust manfold on my gsr swap I just got from IAS and noticed two nuts were missing, one bolt was snapped and there is some sort of sealant all over the gasket. I left Larry Jr a message but I doubt he will do anything about it.
Here's some pics:
Old Jul 18, 2003 | 12:52 AM
GZR4DR's Avatar
Default Re: How to Remove Broken Header Stud Bolt (Stripped Honda)
Omg to funny. Person should realize that the exhaust gasket can be reused. And you never use silicon except on a couple rubber gaskets (valve cover, oil pan, cam seals, ect..).
Old Jul 19, 2003 | 07:54 AM
Default Re: How to Remove Broken Header Stud Bolt (GZR4DR)
I got the stud out. Here's a link: https://honda-tech.com/zerothread?id=567450
Old Jul 19, 2003 | 08:01 AM
MrTodd's Avatar
Nice writeup! I just broke a stud off when I installed my DC header just a week ago. Gonna fix it on my next day off...
Old Jul 19, 2003 | 10:14 AM
Phastnphun's Avatar
Here's some pics:
Talk about cheeseballin it! That would never fly with me!!! I guess thats why my stuff never leaks! I do it right the first time. He should have used THE RIGHT STUFF not red RTV. LOL
tensaiwung
27
Mar 28, 2012 10:02 AM
98ekgsr617
Sep 5, 2009 12:52 PM
tpot90
Apr 5, 2008 09:46 AM
akademikz26
Aug 23, 2006 04:28 PM
PatrickGSR94
Apr 28, 2002 03:56 AM
