broken header bolt.
Old Aug 23, 2006 | 12:42 PM
akademikz26's Avatar
Default broken header bolt.
any suggestions of how to extract a broken bolt from the header? the bolt was overtorqued and snapped in half and the other half is stuck inside the head. any suggestions?
Old Aug 23, 2006 | 12:43 PM
93supercoupe's Avatar
Default Re: broken header bolt. (akademikz26)
does it stick out of the head at all, a pic would very helpful
Old Aug 23, 2006 | 12:46 PM
no. the bolt does not stick out whatsoever. its pretty deep inside.
Old Aug 23, 2006 | 12:47 PM
MotorMouth's Avatar
Default Re: broken header bolt. (93supercoupe)
weld something on to it.
Old Aug 23, 2006 | 12:49 PM
Default Re: broken header bolt. (MotorMouth)
my best guess was to use an extractor drill and drill it out, but then again, my only concern is that if i drill it out in a certain angle, i'll mess up the head, which is gonna cost me a lot.
or drill it
Old Aug 23, 2006 | 12:51 PM
but i'm trying to replace it with a new bolt, which i bought from the acura dealer. i have an exhaust leak.
Old Aug 23, 2006 | 01:17 PM
adseguy's Avatar
Drill a VERY small hole centered into the stud. Then get an extractor bit and it should come out with ease and striaght if you did the first part correctly.
I have done this aroun 4 -5 times and by the last time I found that this method was the best. Good luck
Old Aug 23, 2006 | 01:34 PM
JDM_EM1's Avatar
here u go
https://honda-tech.com/zerothread?id=567450
Old Aug 23, 2006 | 01:41 PM
Default Re: broken header bolt. (JDM_EM1)
do you suggest using a 1/8" drill bit? cuz i bought a 7/64" drill bit to drill the hole
Old Aug 23, 2006 | 01:59 PM
Muckman's Avatar
Moderator in Chief
Default Re: broken header bolt. (adseguy)
If that doesnt work, drill the entire bolt out with a larger bit and helicoil it. You'll learn to appreciate your torque wrench after this. Have fun.
Old Aug 23, 2006 | 04:28 PM
Tactic$'s Avatar
I agree with adseguy. Drill a hole in the center of the busted stud. BE SURE TO HIT THE CENTER!
Use the extractor and twist that son-of-a-bitch out.
Then buy ARP and don't worry about it again.
lilo_goki
Jun 9, 2008 12:18 PM
danteisme
Oct 14, 2006 10:36 AM
BeesDA6
Jul 17, 2003 04:44 PM
EF_LSVtec
Oct 3, 2002 06:30 AM
