92 EG with B18c swap driving issues
Old Jan 21, 2013 | 07:15 AM
TotalKhaos24's Avatar
Default 92 EG with B18c swap driving issues
Got a problem with a buddys car. Its a 92 EG with a swaped B18c and B18c trans, wire tuck, P30 chipped ECU with launch control. The problem is when hot and hard accelerating the car runs rough (like misfiring condition and or fuel cut/ sputters and then gets up and goes). Also I noticed that when the conditions happen the MPH goes to 0 and the RPMS bounce We already swapped ECU's with a chipped P28 still the same. Tested and removed the speedo gear sensor (ok). Swapped the dizzy (OBD1) and still the same. Tested the MAP sensor and its good. Tested the TPS and kinda wierd, throttle body closed its about .587v when it starts going to WOT the volts increace normal to about 4.012v the the volt meter goes into an open condition like almost at WOT. We have yet to swapped the throttle body with the sensors Im not shure what the TPS range is supposed to be. That is about it. Please help or point in the right direction cuz Im about lost right now and getting brain fried.
Old Jan 21, 2013 | 07:19 AM
Former User's Avatar
Default Re: 92 EG with B18c swap driving issues
New swap that has never run well? Or old swap that has run well but recently isn't?
CEL codes?
Last ignition system tune up?
Old Jan 21, 2013 | 07:48 AM
Its and old swap about 8 months, no codes due to the intermittent conditions. Tune up was about a month ago with honda part. Like I said cold its good but when car gets to operating temps thats when the problem happens. I've had the problem on my CRX and a few days after the car would not start traced it to the dizzy being an open internally. Like I said we replaced it on the EG and its still happening.
Old Jan 21, 2013 | 07:54 AM
I was thinking of the fuel pump next. Running fuel pressure testing and seeing when the conditions happen what happens to fuel pressure.
Old Jan 21, 2013 | 07:57 AM
Buddy just texted me and said he noticed that the radio and headlights shut on and off while is bucking during the conditions.
Old Jan 21, 2013 | 08:06 AM
CEL codes?
1) Unplug the O2 sensor to see if the problem goes away.
2) Have the alternator tested.
Old Jan 21, 2013 | 09:25 AM
I'll try that and let u know. thankx.
Old Jan 21, 2013 | 10:01 AM
Your the man RonJ thankx its the O2 sensor. Swapped it and it works cherry tested it over 6 times now and no problems. Thankx again.
Old Jan 21, 2013 | 10:02 AM
92hxEG
21
Feb 26, 2017 08:52 AM
EgB18c406
Jun 2, 2013 08:36 PM
NoMercy28100
Feb 24, 2013 07:00 AM
R_type
Dec 9, 2006 08:27 PM
chuniepatuni
May 14, 2006 11:08 AM
