EG Sunroof Problem!
Old Jan 20, 2013 | 12:42 AM
Wilka's Avatar
Default EG Sunroof Problem!
Can't figure out why the sunroof is sagging in the rear, I just did an overhaul of my sunroof with new glass and everything but it was missing the allen screws so I took one to the parts store and tried to match the threads, thing is, there still seems to be slack, should I bite the bullet and order new bolts or are they not tightented down enough? The front seems like it sits up a little when it's down, and when I try to open it the rear wants to drag my roof?
Old Jan 20, 2013 | 05:54 AM
Former User's Avatar
Default Re: EG Sunroof Problem!
Post pictures. Sounds like the glass is not properly leveled.
Old Jan 20, 2013 | 06:51 AM
deschlong's Avatar
Oh look, I can change this
Loved
Community Favorite
Note that those "special washers" only apply to a 1992 model. Later years did not have / require the special washers.
Old Jan 20, 2013 | 06:59 AM
Interesting. So after 1992, shims were used, like in my 00 Civic?
Do you have a diagram for the height adjustment procedure for 93-95 Civics?
Old Jan 20, 2013 | 08:16 AM
deschlong's Avatar
Loved
Community Favorite
Not sure so much about the shims; I seem to recall there being nothing at all (which was confusing at first since I was going off the 1992 manual). Anyway, I can confirm since I also have both the 1993 and 1995 Civic Service Manuals, but no scanner here at home so a pic will have to suffice. Will post up later today.
Old Jan 20, 2013 | 08:19 AM
Mail to me and I'll convert them to searchable PDF for you.
Old Jan 20, 2013 | 08:24 AM
deschlong's Avatar
Loved
Community Favorite
Hah, you'll scan all 1200+ pages, eh? I can assure you, since I am doing this currently for the JDM Service Manuals courtesy of the large-format scanner at my workplace, that it is a long, boring, monotonous, repetitive job that I wouldn't wish on my worst enemy. Actually wouldn't be so bad if you cut off the spine and scanned as two-sided pages ... alas, I did not have the heart to do that.
Old Jan 20, 2013 | 08:26 AM
Important work is not always exciting.
I agree. Do not destroy the originals.
By the way, the diagram below shows the shims used for height adjustment of the 96-00 Civic moonroof glass.
Old Jan 20, 2013 | 11:33 AM
deschlong's Avatar
Loved
Community Favorite
From the 1995 Service Manual:
I checked the 1993 manual and its instructions are the same as the 1992. However, on my 1993 Si, the mounting is the same as given in the 1995 manual. So, either my sunroof has been replaced (unlikely but possible) or the manual is wrong (also unlikely, but possible). Guess I'll keep an eye out for 93 Civics at the yards and verify how their sunroofs are mounted.
Old Jan 20, 2013 | 11:59 AM
Good to know. Seems like the adjustment procedure was simplified after 1992 but was recomplicated (shims) for 6th generation Civics.
Old Jan 21, 2013 | 06:46 AM
Wilka's Avatar
Should I but the shims anyway even if it's not a 92? I think I'm gunna order the oem screws for it instead of the matched ones from autozone that seem like they might throw it off
Old Jan 21, 2013 | 09:58 AM
MEn'MYEK's Avatar
Should have bought an EK you wouldnt have that problem bro...
Old May 27, 2018 | 05:18 AM
94 Civic Si's Avatar
Premium Member
Loved
Community Favorite
Thanks for this! I need to do this on my '94, but all I could find was the '92 pages w/ special washer...
Old Jun 14, 2018 | 11:52 AM
Premium Member
Loved
Community Favorite
FYI - my '94 Si is as pictured above.
1984eghatch
Dec 29, 2010 03:54 PM
huge230
Oct 23, 2007 05:06 AM
Miracle
Sep 8, 2007 11:14 AM
johnkilo3
Oct 28, 2006 08:57 PM
willy.wonka
Nov 4, 2003 05:04 PM
