97 Civic HX -- Fuel pump won't run
Old Jan 18, 2013 | 03:19 PM
JoshV1288's Avatar
Default 97 Civic HX -- Fuel pump won't run
OK so I have replace fuel pump and main relay but the fuel pump still will not come one with being hooked to a switch is there anything else to check
Old Jan 18, 2013 | 03:21 PM
Former User's Avatar
Default Re: fuel pump issue
Stock 97 Civic? What trim?
Describe how you wired the pump to a switch.
Old Jan 18, 2013 | 03:31 PM
JoshV1288's Avatar
1997 HX. Wire from pump to switch and wire from switch to battery with a fuse inbetween
Old Jan 18, 2013 | 03:35 PM
(Many people want your HX.)
Good. That's clear.
Now also run a wire from the - battery post to the black ground wire for the fuel pump. When you flip the switch, does the fuel pump now run?
Old Jan 18, 2013 | 03:38 PM
JoshV1288's Avatar
The fuel pump runs on the switch I want it to run how it did stock without the switch
Old Jan 18, 2013 | 03:40 PM
Hmmm...this^ isn't what your first post says, right?
Voltage test installed fuses 44 and 13.
Check whether the G101 ground on the thermostat housing is clean and tight.
When you turn the key from off to ON(II), does the CEL remain on steady?
Any CEL codes?
Old Jan 18, 2013 | 03:46 PM
JoshV1288's Avatar
Default Re: 97 Civic HX -- Fuel pump won't run
OK wat is CEL
Old Jan 18, 2013 | 03:47 PM
OK wat is CEL
See Codes sticky at the top.
Old Jan 18, 2013 | 03:55 PM
JoshV1288's Avatar
OK it works now idk I just fliped the fuse in 13 and it came on lol
Old Jan 18, 2013 | 03:57 PM
Magic!
00trdtaco
Audio / Security / Video
Aug 20, 2009 09:42 AM
00trdtaco
Aug 20, 2009 06:42 AM
EJ8 GSR-T
Dec 25, 2006 06:46 PM
94delsol6428
Dec 22, 2006 12:51 AM
ridnmyhonda
Feb 13, 2003 04:23 PM
