b20 vtec questions
Old Jan 16, 2013 | 12:58 AM
ribal_gh's Avatar
Default b20 vtec questions
Hi Guys,
already read the famous thread about building LS/b20 vtec but i got a few questions whose answer was not there.
1- Is is preferable to use high comperssion pistons on b20b block?
2- Is it safe to run 11.5:1 compresion pistons on stock rods (b20b)?
3- Is there any other mods that should follow when using such pistons?
4- Finally, is it woth spending about $500 on High Comp pistons !! what is the estimated hp gain compared to using stock pistons on b20?
thanks
Old Jan 16, 2013 | 03:19 AM
Disco's Avatar
Default Re: b20 vtec questions
Any time you raise the compression you will see power gains. How much gain can really only be determined by the rest of the surrounding parts. As for the stock rods I've seen them handle 26+ lbs of boost and 400hp in a drag only race car that saw no real mileage. I have no idea how long they would last revving over 8k. A good thing to do if you plan on using a stock rod is purchase some ARP rod bolts for some extra insurance. Good luck
Old Jan 16, 2013 | 08:53 AM
gutted-dx's Avatar
RS Machine pistons. They fit on stock rods, and they are around 11.5 depending on the head you use.
Old Jan 16, 2013 | 10:28 AM
b19coupe's Avatar
Stock B20 sleeves suck. You want a 2 liter bottom end? Sleeve any B series block(except a B16) and run 84+mm bores.
Old Jan 16, 2013 | 12:10 PM
ribal_gh's Avatar
so you mean i should go for a b18 ? (LS vtec)
but i see many people running 250+ hp on the stock b20 sleeves!
and its bieng reliable.
Old Jan 16, 2013 | 12:20 PM
ribal_gh's Avatar
OMG 310$ for each piston
Old Jan 16, 2013 | 12:32 PM
EsotericImage's Avatar
Retired Moderator
Theres others out there for 199 a set.
http://www.ebay.com/itm/YCP-B16-B18-...-/190775982869
these pistons with a P8R head the CR is around 11.1, P75 head and its 11.5, Vtec heads are 12+
Old Jan 16, 2013 | 02:09 PM
b19coupe's Avatar
Icon2 Re: b20 vtec questions
Lots of people will claim to be running stock sleeves, revving to 9,000 RPM all day long, running 20 PSI no problem, etc.
I have seen more cracked B20 sleeves than any other Honda engine by a wide margin. The sleeves are weak. Properly tuned, they may last indefinitely. Or not. If you are going to be sinking your hard earned dollars into something, would you rather be sure, or do you like to live on the edge?
Old Jan 16, 2013 | 02:13 PM
b19coupe's Avatar
Originally Posted by teg92
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LaminaR X &raquo;</TD></TR><TR><TD CLASS="quote">Has anyone had the missfortune of cracking the stock sleeves on a built B20 vtec??</TD></TR></TABLE>
https://honda-tech.com/zerothread?id=398204
https://honda-tech.com/zerothread?id=304251
https://honda-tech.com/zerothread?id=280895
https://honda-tech.com/zerothread?id=280870
https://honda-tech.com/zerothread?id=329921
http://dwolsten.tripod.com/articles/jan96a.html
Credit to teg92 for doing a search back in 2003.
Originally Posted by earl
Do all the rings spin freely while in their ring land. If so, the pistons are probably ok. Just replace the rings. If you look at a B20 funny, it will crack on you for no reason. Just a weak block.
RIP Earl Laskey. He was in the Honda engine sleeving business and knew just a bit about the subject.
Old Jan 16, 2013 | 03:44 PM
UncleD's Avatar
Gotta pay to play. Simple as that.
Old Jan 17, 2013 | 12:28 AM
ribal_gh's Avatar
ohh another $600 seems the full project will cost about $3000.
damm i dont think its worth spending this amount about for an additional 50hp
anyway thanks guys for the info.
Old Jan 17, 2013 | 11:10 AM
UncleD's Avatar
NA power is the most expensive to make. This is no secret.
EG6-MonSTa
13
Dec 20, 2009 12:47 AM
lsvtec2000
Feb 4, 2008 02:26 PM
blackassasin95
Nov 4, 2004 10:38 PM
PanamaVTI
11
Feb 12, 2004 12:39 PM
baybeboi
Oct 5, 2003 06:45 AM
