ls vtec turbo lose power in 4rth gear
Old Jan 9, 2013 | 04:58 PM
carlos8's Avatar
Default ls vtec turbo lose power in 4rth gear
my car is losing power when i shift to 4 gear but is for 1 second then
start to spin the tires again. It's like a instant drop of power, she is tuned and
nothing was touch. Maybe my intercooler is to small 28x7x2.5? The clutch is not sliping.
383whp@17psi
sc34
9.0:1 srp
gsr cams
650cc inj
28x7x2.5 ebay ???
Old Jan 9, 2013 | 05:52 PM
BLU CIVIC's Avatar
Track Advocate
Default Re: ls vtec turbo lose power in 4rth gear
engine management? Had this problem
Old Jan 9, 2013 | 07:38 PM
v8eatrr's Avatar
Same thing happend to me today
I had a clamp loose on the charge pipe
Would build boost fine and hold it
Drop when I shifted and then build slowly for a second and then fast again
Check all the clamps out
Old Jan 10, 2013 | 12:01 AM
carlos8's Avatar
i use crome pro
V8 good advise i will check all the couplings and clamps.
Old Jan 10, 2013 | 05:26 AM
SiRCiviC94's Avatar
What map sensor?
Old Jan 10, 2013 | 06:14 AM
carlos8's Avatar
omni 3 bar
Old Jan 10, 2013 | 06:46 AM
wantboost's Avatar
Who is Mr Robot?
You always go for the map sensor being bad.... that's not always the problem so shut the **** up
Old Jan 10, 2013 | 12:28 PM
carlos8's Avatar
reajust all the t-bolts and check the couplings all loock fine. Can't check the
car cause it's raining so heavy.
Old Mar 23, 2013 | 01:29 PM
carlos8's Avatar
hi guys, been a wile since the problem start but work and D.D. car issues have me busy.
the car still running strong the firts 3 gears but whit the same problem when
shift to 4th a little fall in power for a second and then hit again.
no boost leaks.
Greg1995Civic
Oct 23, 2014 07:54 AM
turbo89civicb18hatch
Mar 11, 2004 10:59 AM
Fired Honda
Jun 26, 2003 08:43 PM
teknical1
Feb 8, 2003 07:50 AM
turbogsr13z
Jul 31, 2002 04:17 AM
