94 honda civic failing emissions need help
Old Dec 22, 2012 | 11:18 AM
Eg Fool's Avatar
Default 94 honda civic failing emissions need help
i have a 94 civic ex with a jdm d15b engine. other than that, the car has zero modifications. i changed the oil yesterday, new plugs, the car has the infamous bad idle (i cleaned out the iacv yesterday, though not as bad the issue is still prevalent).
i passed every portion of my inspection except for the low speed hc (ppm).
220 to pass, my car hit 278 (after everything mentioned above) any ideas?
thanks in advance
Old Dec 22, 2012 | 11:33 AM
Eg Fool's Avatar
Default Re: 94 honda civic failing emissions need help
also my distributor is maybe 3-4 months old
Old Dec 22, 2012 | 05:43 PM
Eg Fool's Avatar
bump
Old Dec 22, 2012 | 06:22 PM
Rusty94cx's Avatar
Did you run the. Car for a good little bit on the freeway prior to testing? Heard that it helps?
Old Dec 22, 2012 | 08:50 PM
hwyix's Avatar
scan in your smog test.
I would retard your timing the max amount that is allowed to pass smog. That will help with HC. Your so close to passing you could probably just drive your car hard on the freeway before testing and you will probably pass.
I would only use OEM plugs/wire/cap/rotor/distributor.
Old Dec 22, 2012 | 08:55 PM
tjdmcoupe's Avatar
run it hard to get the cat as hot as possible. Make sure ignition timing is near perfect. if all else fails, replace the CAT for a new one.
Old Dec 23, 2012 | 02:21 AM
fasterthanueg's Avatar
What ecu? Is it chipped? Sometimes the chip will cause a funky idle from my experiences.
Old Dec 30, 2012 | 10:38 AM
Eg Fool's Avatar
been busy with holiday weekend and all. ran it hard today, i have a auto p28 converted to manual, no cel for anything. my odd idle is present half the time, no idea why. getting it inspected again to see what happens.
Old Dec 30, 2012 | 11:00 AM
Ryan96GSR's Avatar
Take it for a good drive on the highway(like previously mentioned) and try and have the car roll onto the dyno without having the car shut off.
Old Dec 30, 2012 | 12:49 PM
Eg Fool's Avatar
last bump.
passed with flying colors at another place. no idea what changed, other than their faulty equipment.
Old Dec 30, 2012 | 12:50 PM
Eg Fool's Avatar
i did more or less this after searching for another place while i charged my phone in the car. if this is what solved the issue than i recommend everyon doing it.
Old Dec 30, 2012 | 11:19 PM
hwyix's Avatar
If your HC was 1000 warming up the cat would not do it. Your HC was 278 and you only needed 220 to pass.
ANNiHiLATORS
24
Aug 25, 2012 09:16 AM
theslugbug
Sep 29, 2009 11:01 PM
thewrai6th
May 15, 2008 09:13 AM
Civic-Kids
Dec 11, 2007 01:26 PM
White95SiHB
Jun 26, 2007 12:39 AM
