94 honda civic failing emissions need help
i have a 94 civic ex with a jdm d15b engine. other than that, the car has zero modifications. i changed the oil yesterday, new plugs, the car has the infamous bad idle (i cleaned out the iacv yesterday, though not as bad the issue is still prevalent).
i passed every portion of my inspection except for the low speed hc (ppm).
220 to pass, my car hit 278 (after everything mentioned above) any ideas?
thanks in advance
thanks in advance
Re: 94 honda civic failing emissions need help
scan in your smog test.
I would retard your timing the max amount that is allowed to pass smog. That will help with HC. Your so close to passing you could probably just drive your car hard on the freeway before testing and you will probably pass.
I would only use OEM plugs/wire/cap/rotor/distributor.
run it hard to get the cat as hot as possible. Make sure ignition timing is near perfect. if all else fails, replace the CAT for a new one.
been busy with holiday weekend and all. ran it hard today, i have a auto p28 converted to manual, no cel for anything. my odd idle is present half the time, no idea why. getting it inspected again to see what happens.
Take it for a good drive on the highway(like previously mentioned) and try and have the car roll onto the dyno without having the car shut off.
last bump.
passed with flying colors at another place. no idea what changed, other than their faulty equipment.
i did more or less this after searching for another place while i charged my phone in the car. if this is what solved the issue than i recommend everyon doing it.
ANNiHiLATORS
24
08-25-2012 09:16 AM
thewrai6th
05-15-2008 09:13 AM
White95SiHB
06-26-2007 12:39 AM
