Relocating battery, how to wire starter wire to battery with high output alternator?
Old Dec 19, 2012 | 10:58 AM
jc95148's Avatar
Default Relocating battery, how to wire starter wire to battery with high output alternator?
I am halfway in the process of relocating my battery to my trunk. I can't really run it through the stock fusebox because of the H/O alt. So as of now I have 4ga running from alt to battery with a 100amp fuse 4 inches away from battery. Now my problem is how am I going to wire my starter wire? Could I just extend it and make it go to the trunk and weld the stock one to it? Please help since I see people running the battery wire to the starter but using stock fusebox. I have a 2000 Civic btw. Thanks!
Old Dec 19, 2012 | 11:26 AM
delsolo95's Avatar
Default Re: Relocating battery, how to wire starter wire to battery with high output alternat
heres a diagram of what i did. I had zero problems setting it up this way. hope this helps
Old Dec 19, 2012 | 11:53 AM
jc95148's Avatar
So what fuse size did you use for each wire in the distribution box?
Old Dec 19, 2012 | 11:58 AM
jc95148's Avatar
Also is it ok to run the alternator wire to the starter with a fuse block and have another wire running from the starter to the battery in the trunk?
Old Dec 19, 2012 | 12:21 PM
delsolo95's Avatar
only fused wire ran was the 100 amp for the battery.
I don't think you want to do that. you ever started you car while the engine is already running? that is what its going to do.
Old Dec 19, 2012 | 12:24 PM
delsolo95's Avatar
you dont need a distribution block from battery to fuse and starter, i put one there for easy disconnect. if you dont use one make sure you solder and wrap it up good
my distribution block looked like this
Old Dec 19, 2012 | 12:26 PM
jc95148's Avatar
Why would it do that, isn't it basically the same thing as connecting it directly to the battery?
I saw it on here, can you please clarify.
http://grassrootsmotorsports.com/for...n/34794/page1/
Old Dec 19, 2012 | 12:33 PM
delsolo95's Avatar
oops i take that back. i thinking the wrong thing. i guess you could do it like that but id do it like my diagram. ive had it that way for almost a year with no problems, cant go wrong with that
Old Dec 19, 2012 | 12:36 PM
jc95148's Avatar
I don't want to run too many wires, so if I do it my way (the one in the link) what wires would you suggest for me to install a fuse box? Alt. to Starter Wire, Starter to Relocated Battery Wire?
Old Dec 19, 2012 | 12:55 PM
delsolo95's Avatar
im not a wire guru but i would think a 6awg battery cable wire would do since thats what im using
Old Dec 19, 2012 | 01:01 PM
jc95148's Avatar
I already have 4 gauge but where should I put the fuses at? The wire from starter to battery or starter to alternator or both?
Old Dec 21, 2012 | 08:53 AM
delsolo95's Avatar
i dont have the starter or alternator fused. you should be fine if your gonna connect it back to the underhood fusebox i assume
c|rop3asy==[]
Sep 9, 2013 11:17 PM
jc95148
Audio / Security / Video
Dec 20, 2012 06:42 AM
steveharrmr23
Sep 14, 2009 11:45 AM
91EF919
Apr 6, 2009 08:27 PM
philkehn
21
Jul 5, 2006 08:29 PM
