Relocating battery, how to wire starter wire to battery with high output alternator?
I am halfway in the process of relocating my battery to my trunk. I can't really run it through the stock fusebox because of the H/O alt. So as of now I have 4ga running from alt to battery with a 100amp fuse 4 inches away from battery. Now my problem is how am I going to wire my starter wire? Could I just extend it and make it go to the trunk and weld the stock one to it? Please help since I see people running the battery wire to the starter but using stock fusebox. I have a 2000 Civic btw. Thanks!
Re: Relocating battery, how to wire starter wire to battery with high output alternat
heres a diagram of what i did. I had zero problems setting it up this way. hope this helps
Also is it ok to run the alternator wire to the starter with a fuse block and have another wire running from the starter to the battery in the trunk?
only fused wire ran was the 100 amp for the battery.
I don't think you want to do that. you ever started you car while the engine is already running? that is what its going to do.
you dont need a distribution block from battery to fuse and starter, i put one there for easy disconnect. if you dont use one make sure you solder and wrap it up good
my distribution block looked like this
I saw it on here, can you please clarify.
http://grassrootsmotorsports.com/for...n/34794/page1/
oops i take that back. i thinking the wrong thing. i guess you could do it like that but id do it like my diagram. ive had it that way for almost a year with no problems, cant go wrong with that
I don't want to run too many wires, so if I do it my way (the one in the link) what wires would you suggest for me to install a fuse box? Alt. to Starter Wire, Starter to Relocated Battery Wire?
im not a wire guru but i would think a 6awg battery cable wire would do since thats what im using
c|rop3asy==[]
09-09-2013 11:17 PM
jc95148
Audio / Security / Video
12-20-2012 06:42 AM
