98 civic - need to manually push power window up
Ok well my bro has a 98 civic and he has power wondows but the window goes down and up but he has to manualy push the window up to get it to stay up and if you push down it will go down. My sister had that problem on a jeep and was a plastic piece wearing out. Is this the same? And anybody got pics so we can grab sone tomorrow thanks
Re: 98 civic - need to manually push power window up
Older Jeeps I've worked on don't use the same style regulator that Honda does.
The regulator on my '00 EX just fell apart at the upper joint near the motor. (see below) It's just a press fit with a washer holding it on a hollow shaft. I put a bolt through the hole and secure it with a nut instead of a washer. Good to go.
98civ98
02-04-2014 02:40 PM
