Transmission & Drivetrain Gearboxes, Differentials, Clutches
transmission issues
Old Nov 29, 2012 | 06:25 PM
liljukmoves's Avatar
Default transmission issues
hey everyone i was replacing my clutch everything was going smoothly till it came to reinstalling the transmission. i cant get it to wanna go back on there is a large gap between engine and transmission i cant figure out how to close it. used the given alignment tool, i greased the drive shaft, throw out Bering tried starting over 3 times i did everything according to what this guy said to do http://www.honda-acura.net/forums/do...l-58-pics.html please help is there something im forgetting to do?
Old Nov 29, 2012 | 06:49 PM
Laughing Man's Avatar
Default Re: transmission issues
Sounds like the splines on the transmission and the clutch are not aligned.
Old Nov 30, 2012 | 10:10 PM
i moved the flywheel a little and it worked only other thing is my clutch hops a little bit at low rpm and even after bleeding the clutch line the clutch pedal feels light do you think i need to replace the master or slave cylinder?
Old Dec 1, 2012 | 09:22 PM
not so civic's Avatar
From: gravity rides everything...everything will fall, se GA/ne FL
What pressure plate did you install? If its a stock replacement it feels light. Have someone pump the clutch and see how much the slave moves. Check for fluid leaks at the piston dust boot seals. They should not be excessively wet.
kaivorth
Honda Civic (2001 - 2005)
Apr 3, 2017 07:17 AM
mrccupid3
May 8, 2009 07:09 AM
Vtec_Dude
Jun 10, 2007 10:44 AM
InitialJRift
Sep 13, 2006 10:43 AM
KooK
Jul 11, 2002 03:28 AM
