92 Honda Civic Si overheating, Need Help!
Old Nov 25, 2012 | 11:24 PM
doubleoazn03's Avatar
Default 92 Honda Civic Si overheating, Need Help!
My EG Hatch has been over heating. Coolant was leaking from what looks like the bottom of my radiator. So I decided to change the Radiator and might as well changed the thermostat, thermo seal, coolant temp sensor, fan switch, upper and lower radiator hoses too. I changed everything and it still overheats. Before the repairs, coolant leaked from the bottom of the rad, the idle was bouncing up and down and my fan never kicked on, my lower rad hose was not hot, it was cold but the upper hose was hot. Also the heater was not blowing hot anymore.
I would like to know what you guys think? I was thinking its a toss up between the water pump and the heater core
Old Nov 26, 2012 | 03:39 AM
Lizardslap's Avatar
Default Re: 92 Honda Civic Si overheating, Need Help!
probably a blockage somewhere flush it could take the heater core out and flush that to or replace
Old Nov 26, 2012 | 10:44 AM
So forget the waterpump as a possibility?
Old Nov 26, 2012 | 11:49 AM
Lizardslap's Avatar
I wouldn't completely discount it but they dont go bad as often
you described pretty much a blockage somewhere in the cooling system dont forget to bleed your cooling system real good air in the system can also cause you some problems
Old Nov 26, 2012 | 12:20 PM
B20DelSol's Avatar
Try running it with the radiator cap off with someone watching the temperature gauge just in case. Let it warm up, and add coolant as necessary. Then, check if there is coolant running into the radiator from the upper radiator hose. This will mean that the thermostat is opening and coolant is getting pumped through the engine.
dbailey
11
Jan 30, 2020 04:27 AM
Edwin Reyes
Jan 17, 2016 01:42 PM
4doorpowa
Jan 24, 2011 12:50 PM
corince06
Jun 11, 2008 12:48 PM
MPALUGHI
Aug 15, 2005 12:49 PM
