Dizzy help
H23 vtec 00 accord swap/ Dizzy is td60u
I installed a new dizzy but car won't start
this is the website I took the wiring off of
http://importnut.net/h22a_swap.htm
Your car has the crank sensor at the oil pump, but your distributor has a crank sensor inside it(obd1). Did you have any extra wires hanging around the distributor ? It probably would have been best to just get an obd2 h22a distributor.
My engine had the Crank, TDC, and Cylinder position sensor in the distributor. That distributor the cylinder sensor went out. All my wires are connected the same way I had them on old TD94u distributor.
With new dizzy I get spark but no start
also starts but dies right away
td60u is an obd1 distributor.
http://www.hondapartscheap.com/parts...p-oil-strainer
Part number 18
Your crank sensor should be at the oil pump unless there was already some work done previously that you didn't disclose.
Part number 18
What exactly did td60u mean as posted by you ?
Angeljavier3577
Apr 30, 2018 01:41 PM
raidacaipo
May 18, 2009 08:57 AM
