civic 98 lx 218 miles per full tank?!! HELP
i got 98 LX, lowered on 15s, totally stock, has 190xxxmiles!
how can i improve my gas mileage?
i used 90 octane fuel and did 218 miles on a full tank.
any help please?
Thanks
any help please?
Thanks
First off, what's the method on your octane? It should say right on the pump.
Second off, when was your last full tune-up? Plugs, wires, cap, rotor, air/oil filters, oil change?
Third off, start driving your car like a grandma. If you're revving past 3k, you're doing gas mileage wrong.
I do regular changes every 3k. I drive like a grandma. And i notice some slipping on my a/t gear at the 2nd gear but not that much
That's around 18-23mpg....
Using higher octane isn't necessary, am I wrong?
A Honda Civic isn't a race/exotic/luxury/sports car, it was meant to be a typically reliable commuter of its time, hence the root word Civil/Civilian/etc.
Any CEL's? Any problems at all? You didn't answer the question regarding a tune-up.
Ignition: Distributor cap, rotor, plugs, wires.
Fuel: Filter, maybe even pump
Air filter, oil etc;
Engine ignition/mechanical timing in check? Intake manifold having any vacuum leaks?
Are you constantly blasting the A/C?
Exhaust system fine? No O2 sensors bad, or a P0420 code?
Time for a tune up, usual suspects.
Plugs
rotor
air filter
etc...
Keep in mind it has 190K
She aint what she used to be.
Id also ditch the 91 octane gas
Plugs
rotor
air filter
etc...
Also, poor wheel alignment can loose you MPG. You must also realize you have and AT. Although you should be getter better MPG, you are loosing a lot of efficiency in that old transmission.
i have no CEL, i checked the o2 sensors and they read good as new, i do regular oil changes,i do change my fuel filter from time to time, but usually every 6 months. how often should i change my spark plugs wires, i never changed those, and never changed my rotor and cap as well. it used to do better while using ac in the summer, all my trips are inside the city as well.
at 190k, you should replace them now. They are technically "lifetime" parts, but for optimal running, they should still be replaced. I personally replace them according to the FSM for plugs, which is every 30k/24mo.
queensny
Oct 6, 2009 07:11 PM
