replacing piston rings on b16a
Old Nov 12, 2012 | 05:00 PM
marco562's Avatar
Default replacing piston rings on b16a
My car seems to be burning oil.. when vtec starts I notice that blue smoke is coming out the exhaust
Does any one know how much will I need to pay for parts n labor?
Old Nov 12, 2012 | 05:03 PM
Fliptard's Avatar
Default Re: replacing piston rings on b16a
could be rings and or valve stem seals.
Old Nov 13, 2012 | 05:55 PM
marco562's Avatar
Thanks for the info.
Old Nov 16, 2012 | 06:13 AM
hondalx97's Avatar
compression test will tell you which
Old Nov 16, 2012 | 07:46 AM
jbpnoman's Avatar
No, it won't. A leakdown test will.
Old Nov 16, 2012 | 08:16 AM
kyden's Avatar
actually a leakdown test won't tell you either. stuck oil rings or worn valve guide won't show up on a leakdown or compression test.
more than likely on acceleration is oil control rings.
Old Nov 16, 2012 | 08:22 AM
tron_'s Avatar
10 Year Member
do a compression test along with a wet and dry leakdown test. report back and we can help you better from there
Old Nov 16, 2012 | 10:35 AM
dirty19's Avatar
Ridin Dirty in Cali
Why not eliminate both and rebuild.
Problems would be solved on both areas then, plus you now have a fresh engine.
Old Nov 16, 2012 | 11:25 AM
RT_NEWYORK's Avatar
I agree. If you can do it yourself would save a bunch of money too.
Old Nov 16, 2012 | 12:04 PM
98civdx's Avatar
Master Detailer
I agree.
If you replace the rings, you might as well spend a couple more bucks and throw some valve seals in it.
Old Nov 19, 2012 | 10:59 AM
marco562's Avatar
I wish I could do it my self but I don't got the experience necessary to do that job.
My b16 has the head rebuilt but the block is not .
vinuneuro
Apr 25, 2007 10:13 AM
silverboost
Nov 8, 2005 01:01 PM
DANG YO
Nov 24, 2003 04:26 AM
DxTrix
Aug 15, 2003 04:58 PM
Dodger2940
Aug 18, 2002 01:06 AM
