Chips at top of RS sleeves (Pics)
Old Nov 4, 2012 | 12:02 PM
norcalB18's Avatar
Default Chips at top of RS sleeves (Pics)
Hey Honda-Tech.
Today I took apart an old RS machine sleeved block that has been sitting for a few years. When I took it apart I noticed there are some Chips at the top of the sleeve. What causes these? Is the block still okay to run? Will I run into compression or sealing problems? I plan on doing 450whp+ on the block but want to make sure its safe before I slap everything together.
Here are some pictures of the biggest chip I have on the sleeves, which is located on Cylinder #1. All the other chips surrounding the block look very minor compared to this one.
Also how are my cylinders walls looking by Eye. (I know you can't tell much but just chime in if you spot something)
Old Nov 4, 2012 | 12:33 PM
bgdriver's Avatar
Default Re: Chips at top of RS sleeves (Pics)
Just have the chip decked off at a machine shop. I would have it honed at the same time.
Old Nov 4, 2012 | 01:10 PM
rich7777's Avatar
Get your machine shop to look at it and get their opinion. I don't like the look at it. Have you got a rough depth ? Is it easy to catch with your nail ? (Pictures can be decisive)
Old Nov 4, 2012 | 05:06 PM
norcalB18's Avatar
From what I hear RS machine sleeves cannot be decked because they are a "step" style sleeves. I guess this means they are initially slightly uneven untill the head is mounted. This is what a shop who builds alot of Hondas told me but if anyone has decked these sleeves before pls let me know how it went.
I'll try my best to describe it in words to help the picture become clear...
When touching the edge of the outer cylinder wall it feels sharp like a 90 degree angle untill it gets to the chipped part.. Where it feels slightly rounded off. (This is the outer wall I'm talking about not the inner)
A question for the theoretical geniuses out there.... Should a cylinder completely hold pressure right at the inner edge of the sleeve? If this was the case maybe it's good to go because the block is chipped on the outer sleeve?
Will take it to q machine shop but have to wait till next week.
Old Nov 5, 2012 | 08:00 AM
TKERacer619's Avatar
Did you run antifreeze in that block? Looks like it had just straight water.
Old Nov 5, 2012 | 08:10 AM
norcalB18's Avatar
Yes I ran anti-freeze. The block was sitting for a few years though.
Anyone know if its okay or not? Or weather its true RS sleeves cannot be decked
Old Nov 5, 2012 | 11:54 AM
vtechjunkie's Avatar
I have only ever seen a step-deck from RS. I however, did not know that the sleeve itself was different. Sounds odd really. I would think the sleeve was made out of cast iron like most, and then decked to a step. But I would go with out the deck anyway. I like the o-ring route, but only when using a copper o-ring. Stainless just kinda scares me to use in an otherwise aluminum block and head. Your machine shop can tell you for sure though.
Old Nov 5, 2012 | 01:57 PM
artie89's Avatar
why dont you just call RS machine (562) 926-0283
Old Nov 6, 2012 | 12:16 PM
Mr.Spec's Avatar
do not deck any sleeved blocks. we had a lotta issues with blowing headgaskets in the past.
Old Nov 6, 2012 | 02:11 PM
Jdm_SiVtec's Avatar
take it to a shop and see what they say
better to be safe then sorry
Old Nov 8, 2012 | 11:16 AM
norcalB18's Avatar
I Honestly don't know why I didnt in the first place..
Sent RS machine the pictures and they said they would have no problem running this block. So I guess I'm goin to run it.
TravisBiggie
Oct 18, 2013 05:08 AM
#1DA2HATE
Jan 26, 2010 03:30 PM
2LiterTurboSeR
Jan 9, 2010 02:29 PM
HondaGuy02
Apr 20, 2004 08:43 PM
Desperado
Apr 27, 2003 03:08 PM
