Brakes need pumped after turning
Old Oct 22, 2012 | 01:21 PM
Fliptard's Avatar
Default Brakes need pumped after turning
97 CX hatch, Y8, rear disk swap.
When I back up and turn all the way either way, the brakes need to be pumped back up before they will work, No leaks Changed pads, rotors, brake soft lines, booster vaccum hose, MC, prop valve. Calipers show NO signs of leaking.
Just started doing this about 1-2 months ago, Bleed the brakes properly a million times. Still nothing....
And ideas?
Old Oct 22, 2012 | 03:08 PM
Fliptard's Avatar
Default Re: Brakes need pumped after turning
Problem solved, apparently who-ever put the suspention on put the forks on the wrong side, causing them to hit the calipers.
Old Oct 22, 2012 | 05:04 PM
ccjdm's Avatar
Mine does the same thing after I lowered my 98 civic. I've changed/replaced everything as well. Any ideas?
Keith45
Suspension & Brakes
Mar 17, 2018 12:03 PM
bodiez
24
Apr 7, 2010 05:20 PM
speedfreek128
14
Feb 26, 2009 10:01 PM
anibis
Sep 4, 2004 06:12 PM
integrakilla
12
May 5, 2004 05:08 AM
