Brakes need pumped after turning
97 CX hatch, Y8, rear disk swap.
When I back up and turn all the way either way, the brakes need to be pumped back up before they will work, No leaks Changed pads, rotors, brake soft lines, booster vaccum hose, MC, prop valve. Calipers show NO signs of leaking.
Just started doing this about 1-2 months ago, Bleed the brakes properly a million times. Still nothing....
And ideas?
And ideas?
Re: Brakes need pumped after turning
Problem solved, apparently who-ever put the suspention on put the forks on the wrong side, causing them to hit the calipers.
bodiez
24
04-07-2010 05:20 PM
integrakilla
12
05-05-2004 05:08 AM
