Help w/drivers side window, won't roll up or down
Old Oct 17, 2012 | 06:27 PM
rhdins's Avatar
Default Help w/drivers side window, won't roll up or down
Window is in the rails. I've replaced the switch and the motor. Worked for a while then stopped working again. I've checked the motor and switch and both are good. All fuses are good too.
The only other thing I can think of is that there is actually a broken wire somewhere. Anyone aware of any similar problems? I don't want to redo wiring if I don't have to.
Any other suggestions would be great.
Old Oct 19, 2012 | 02:36 PM
rhdins's Avatar
Default Re: Help w/drivers side window, won't roll up or down
No ideas huh?
To make it even more confusing, I took the door off to check some of the wires for voltage. I stuck the probe from my voltmeter right into one of the wires (through the insulation) to test it, and the window started working. But it's back to not working again.
Bad ground maybe? An exposed wire somewhere messing things up?
Any suggestions would be great.
Old Oct 19, 2012 | 02:38 PM
Ryan Lwin's Avatar
Loose wire and connection.
Thomas Kalita
Honda Civic (2006 - 2015)
Jun 7, 2018 08:06 PM
KPDSM
Jan 2, 2015 04:27 AM
nmb16a
Jun 30, 2010 01:36 PM
dingobat
Sep 21, 2007 11:23 AM
DJ Gurgla GSR
Audio / Security / Video
Apr 3, 2006 11:35 AM
