power windows broke I'm stumped
Old Jun 29, 2010 | 06:38 PM
nmb16a's Avatar
Default power windows broke I'm stumped
OK guys Ive recently pulled my motor out twice in the last month or so and i ran into window problems both times. first time the motor was out my driver window wouldn't open unless the door was open. then i pulled the motor out did the clutch put it all back now neither window works wtf? the only plug that is even remotely close to window wires would be the plug on passenger side but the clutch fluid reservoir. all fuses and relays test good and switches are good but i got nothin. almost wondering if i can straight wire my windows to new switches and bypass everything any help please.
Old Jun 29, 2010 | 07:02 PM
nmb16a's Avatar
Default Re: power windows broke I'm stumped
anything guys im stressin and dealin with mad rain im loosing it
Old Jun 30, 2010 | 07:24 AM
Relic1's Avatar
to get the windows up, yes you can jumper 12V directly to the window motor.
most likely the harness that runs form the chassis to the door has a broken wire or bad connection in it.
Old Jun 30, 2010 | 07:37 AM
nmb16a's Avatar
what wire on the motor ive been tryin to jump it but no luck please help
Old Jun 30, 2010 | 07:39 AM
nmb16a's Avatar
do i jump it at the wires from the switch or direcly from the motor? i have a 96 civic ex i need the wiring diagram for the power windows
Old Jun 30, 2010 | 08:34 AM
nmb16a's Avatar
ok i just need help on hard wiring my windows any help is greatly appreciated
Old Jun 30, 2010 | 09:23 AM
RHD_BB4T's Avatar
+1
Old Jun 30, 2010 | 10:06 AM
Relic1's Avatar
driver's door - red (or red/blue) and yellow (or red/yellow) is the drivers window motor
passenger's door - yellow (orblue/red) and red (or blue/white) is the passenger's window motor.
Keep in mind these wire colors are at the motor not at the switch.
at the respective switch
driver's window motor - red/yellow and red/blue
passenger's window motor - blue/white and blue/red
positive vs negative. no idea, try it one way if it goes the wrong way, switch it.
keep in mind, hard wiring your windows sounds like the easy way out, but it's going to create problems. Fixing the real problem will be the best solution.
Old Jun 30, 2010 | 10:48 AM
nmb16a's Avatar
i pulled the door harness out and the junction plug is shot there is like five wires broke can i bypass that plug and staight wire all the original connections?
Old Jun 30, 2010 | 10:49 AM
nmb16a's Avatar
oh and thanks for the info relic1
Old Jun 30, 2010 | 12:40 PM
Relic1's Avatar
yes you can connect the wires directly around the plug, but if you ever have to remove the door life is going to suck a little more...
Old Jun 30, 2010 | 01:36 PM
nmb16a's Avatar
got it fixed thanks relic1
Lou_EM1
Jan 9, 2012 10:16 AM
GsRrrr
Jun 14, 2011 04:02 PM
esdrunkcuz562
Honda Civic (2001 - 2005)
Aug 24, 2009 10:18 PM
TRYLSTEG808
Nov 13, 2007 08:33 AM
BokudenNYC
Nov 8, 2007 09:28 AM
