Y8 head swap help
Old Oct 4, 2012 | 06:31 PM
Rookiestock's Avatar
Default Y8 head swap help
If anybody can help me it would be appreciated. I cant figure out what to do with the IACV fix. I have a M/T d16y7 block and I got a y8 head and manifold out of an A/T. the only thing I can find for the swap says to do the IACV fix. the 3 wire to the 2 wire plug but 96-00 A/T vtec has the same 3 wire plug for IACV as the y7. Will it work if I just plug the IACV in. And if I plug the 3 wire in do I still have to do the Iacv fix on the ecu side. Or will this IACV just work because they are the same? Thanks in advance if anybody have a cpl answers for me.
Old Oct 5, 2012 | 06:12 AM
kyden's Avatar
Default Re: Y8 head swap help
it will not work with a manual ex ecu, it can't control it. if you're using an auto ex ecu it will work, but you will have a check engine light for transmission codes.
Old Oct 5, 2012 | 08:04 AM
HondaPartsHero's Avatar
Technical Hero
You can add the 2 wire if you drill and tap
http://www.d-series.org/forums/diy-f...-manifold.html
Old Oct 6, 2012 | 06:29 AM
Thanks guys.
Ryan Williams
Sep 12, 2014 06:54 AM
sage0187
Nov 20, 2010 06:44 AM
96jdmciv
Oct 29, 2008 04:25 PM
Curbow_USMC
Oct 25, 2005 10:05 AM
Civiclx
10
Dec 1, 2003 06:41 AM
