Installing a RevHard turbo kit in my R on the 17th...
Old Oct 17, 2002 | 12:16 AM
TaboR's Avatar
New User
Default Installing a RevHard turbo kit in my R on the 17th...
i have the full Revhard 2C kit. tubine, IC, BOV, blablabla
intank fuel pump, FMU, steel fittings.
i have RC 440cc injectors with OBDI P72 with harness
i have Blitz SBC-iD and Blitz DC guages.
i will get the Hondata S200b and tuned at the shop that installed for me.
what else would i need???
My car will be on the road race track, not a drag strip, not mad power that i will need. but i still enjoy driving a turbo, thats why me come to the DARK SIDE! "P
So will 0.5 bar of boost safe for a bone stock ITR motor with 10.6 CR?
Car will be driven on the street some times but will be at the track at every event.
so whats a safe set up?? besides lowering the CR??
thanks for any help~! just want to make sure i did everything right before i fxxked up anything thanks again~
Old Oct 17, 2002 | 01:14 AM
rjardy's Avatar
Default Re: Installing a RevHard turbo kit in my R on the 17th... (FreddyR)
Well it looks good except for one thing.
With an FMU you need to run a INLINE fuel pump. Any high pressure intank will not provide the pressure that you need to properly operate the FMU.
HTH
Rob
Old Oct 17, 2002 | 02:35 AM
sutrusu's Avatar
Default Re: Installing a RevHard turbo kit in my R on the 17th... (rjardy)
he's going to run hondata
Old Oct 17, 2002 | 02:48 AM
rjardy's Avatar
Default Re: Installing a RevHard turbo kit in my R on the 17th... (sutrusu)
It allso says that he has an FMU, just wanting to make sure he had everything ironed out just trying to help
Rob
Old Oct 17, 2002 | 04:28 AM
sutrusu's Avatar
i dUn cAnT reEd!
Old Oct 17, 2002 | 07:20 AM
I Like Boost's Avatar
ditch the intank pump and fmu. get a hondata, INLINE pump, a resister box, some injectors and get that baby tuned! you won't regret it.
Old Oct 17, 2002 | 07:43 AM
PM-Performance's Avatar
Default Re: Installing a RevHard turbo kit in my R on the 17th... (BEe18SeAONe)
is an inline erally needed if a intank is used?
im doing a custom set up now on my R and i already had the intank from previous nitrous set up , would i realy need an inline ./
Old Oct 17, 2002 | 08:28 AM
BoM's Avatar
BoM
Default Re: Installing a RevHard turbo kit in my R on the 17th... (itr206)
if ur using a FMU then u need an inline.
Old Oct 17, 2002 | 08:36 AM
Default Re: Installing a RevHard turbo kit in my R on the 17th... (BoM)
what will happen if you dont use the inline with an fmu?
DCR714 is using the vortech fmu with only the intank 255 from wlbro, the A/f looks great all the way thru the band , but he dyno's like ****?
Old Oct 17, 2002 | 08:50 AM
TaboR's Avatar
New User
so~ i guess i will get a inline fuel pump and some resistor box then~!
but who makes a good inline fuel pump and the resistor box??
how about spark plugs?? would i need to use a spark amp??
thanks for all the helps again~
[Modified by FreddyR, 9:56 AM 10/17/2002]
Old Oct 17, 2002 | 09:38 AM
Slick GS-R's Avatar
bump
Old Oct 17, 2002 | 10:12 AM
MikeMAN's Avatar
Default Re: Installing a RevHard turbo kit in my R on the 17th... (Slick_GS-R)
have fun with the boost!
Old Oct 17, 2002 | 11:31 AM
tygsr's Avatar
Default Re: Installing a RevHard turbo kit in my R on the 17th... (MikeMAN)
Dont get a inline pump, keep the intank with the hondata and use a 1:1 fpr.
94hybridcoupe
Apr 6, 2005 06:53 AM
Rob!
Aug 1, 2004 01:06 PM
socal_brandon_
May 3, 2004 07:42 PM
Obie
Aug 13, 2003 07:37 PM
tygsr
Apr 20, 2002 01:14 PM
