Transmission & Drivetrain Gearboxes, Differentials, Clutches
lsd clunking noise???
Old Sep 20, 2012 | 11:02 AM
dtran002's Avatar
Default lsd clunking noise???
I posted this on prelude forum but no help so i'm going to give a try here.
So I have a 95 Accord with H22a swap. My mechanic said he got me a LSD (aftermarket oem?). It makes clunking noises when turning, but usually stop after driven a period of time. After I changed new clutch, Exedy, the noises are still there regardless of how long I drive the car. Its really bothering me now.
I searched around and some said to use certain type of oil (redline 75w90). Can my trans take that type or is there any other recommendations? Currently using 10w30 regular oil.
Thanks...
Old Sep 20, 2012 | 06:32 PM
David @ Synchrotech's Avatar
Default Re: lsd clunking noise???
It really depends on what type of LSD you have. If it is a helical LSD it does not require a special oil but plate and clutch type LSDs do require a friction modifier and some models need a specific MTF. Hopefully it is not just a cheap *** helical LSD that has pitted gears, broken washers and loose bolts.
Old Sep 21, 2012 | 08:40 AM
dtran002's Avatar
I believe I have the clutch type LSD. Any recommend oils to use?
Old Sep 21, 2012 | 08:53 AM
I like Torco MTF along with Torco Type F friction modifier with a plate style LSD.
Old Sep 21, 2012 | 11:42 AM
dtran002's Avatar
Thank you, i'll look into that and see how many I need.
angryhillbilly
12
May 11, 2013 04:44 PM
dblair
May 3, 2013 01:21 PM
j spec
Feb 15, 2006 01:30 PM
KekeK-18
Oct 22, 2001 01:23 AM
