Preparing for a Sohc Turbo (D16Z6)... What do I need to prepare?
Old Oct 16, 2002 | 10:35 PM
Maverick77's Avatar
Default Preparing for a Sohc Turbo (D16Z6)... What do I need to prepare?
I just wanted to know what parts I need to install or replace before I go ahead and put on a Greddy kit. Will a turbo still be okay on a motor with over 150k miles if I make upgrades and replacements?
Old Oct 16, 2002 | 11:55 PM
vivid02's Avatar
Default Re: Preparing for a Sohc Turbo (D16Z6)... What do I need to prepare? (Maverick77)
Your wallet. Just put it on the stock motor. Buy another D16Z6 and put in some LS rods with JE pistons.
Old Oct 17, 2002 | 04:53 AM
GasHuffer's Avatar
Default Re: Preparing for a Sohc Turbo (vivid02)
if your set on going with the greddy kit for sure instead of a home made kit your pretty much set. its gonna come with a blue box for fuel managment but you might wanna check into a SMC and a set of DSM 450 injectors. Just make sure you got everything before you start, and get some buddies to help.
Old Oct 17, 2002 | 05:18 AM
civicHBphatride's Avatar
I had nothing good to contribute to this thread.
*Edited by your friendly mod y0!*
Old Oct 17, 2002 | 05:23 AM
nijia555's Avatar
Default Re: Preparing for a Sohc Turbo (civicHBphatride)
um yeah there killer
Old Oct 17, 2002 | 05:44 AM
KoRE's Avatar
and anyways a sohc turbo can be made quick someone on here is running 12's and i do to after mine gets back....
Old Oct 17, 2002 | 05:59 AM
VTC_CiViC's Avatar
i think it would be better to do a motor swap
..there's aways 1..
someone with a dual over head vtec with portt and polish head in a cx gutted out will probly still hang with you if not bet you in the 1/4 mile.
LOL, hell yea, those crazy fast B16's yO!!
Old Oct 17, 2002 | 06:03 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: Preparing for a Sohc Turbo (VTC_boost-less_CiViC)
Hey Swap heads, we are not going to turn this into a swap vs. turbo debate. This guy is asking what to do to prep his D16Z for turbo, so unless you help him with THAT question don't bother posting. I will simply delete any swap suggestions.
Old Oct 17, 2002 | 06:09 AM
beandip's Avatar
Default Re: Preparing for a Sohc Turbo (B18C5-EH2)
I would drop the compression ratio a little, that way you can boost more. It depends on how much boost you want. If your looking at 8psi and lower, you should be ok with current ratio, but If you want more, I would drop it to 8:1. I am looking at doing the same thing, but making the homemade kit instead.
Old Oct 17, 2002 | 06:27 AM
VTC_CiViC's Avatar
2 things.
1- Compression test
2- Cylinder leak down test
This will let you know how good your rings are and whether or not you are expereincing any valve leakage.
Assuming all this comes back 100%, I'd still be a little leary of boosting hard on that motor. You're already starting with a 9.2:1 CR so that's a leg-up for you, but as it is, D-series aren't the strongest of the bunch by far, so you'll want to ensure you're running a VERY safe/rich setup. Use the AFC-hack if you wish (if you don't go standalone then this is the route i'd reccomend) and ensure you set it to run richer in the high rpm area. And use GOOD oil!! D16's are notorious for spinning rods
[Modified by VTC_boost-less_CiViC, 10:28 AM 10/17/2002]
Old Oct 17, 2002 | 06:39 AM
racecarpete's Avatar
1- Compression test
ditto
Old Oct 17, 2002 | 07:16 AM
oldskool_rex's Avatar
Prep with a greddy kit? You will be just fine working right out of the box. Only thing is I would make sure your **** is running right before you start. If you are losing power, missing, running like crap, a turbo is not going to fix it.
Only put more money into the motor is you wanna boost more or if you blow it up (which is extremely unlikely with the stock greddy kit).
Old Oct 17, 2002 | 08:20 AM
2camsaam's Avatar
Default Re: Preparing for a Sohc Turbo (oldskool_rex)
You can put LS rods in a D-series motor?
Old Oct 17, 2002 | 11:48 AM
Tomek's Avatar
Default Re: Preparing for a Sohc Turbo (2CAMSAAM)
You can also use b16a rods with supra pistons .....check out turbo panda's posts and you'll learn more about them.
Old Oct 21, 2002 | 01:36 AM
Maverick77's Avatar
I have quite a bit of miles on my car and I'd like to run about 8 lbs. sometimes. Should I get some new pistons, cam, or anything?
Old Oct 21, 2002 | 03:49 AM
POLLO's Avatar
Default Re: Preparing for a Sohc Turbo (AztecEJ)
I'll let you know how that works when my motor is done !
Old Oct 21, 2002 | 06:46 AM
Mike D's Avatar
Default Re: Preparing for a Sohc Turbo (Maverick77)
How much cash do you have? If i were you i would just buy a spare z6 block and build that. You can find them for so cheap.
Plus, this way you can get used to the turbo, tuning, etc. on a stock block. Then when/if it blows replace it with the built block. Less down time too
Mike D
175Shot4Door
Jul 17, 2006 08:20 PM
95phoenEX
May 2, 2006 01:30 PM
dumped_ej1
Apr 6, 2006 10:14 PM
DraconicPenguin
Nov 7, 2005 03:47 PM
