HELP, please lca bolts suck!
i am goin crazy after honda sent me the wrong bolts i finally got new ones and i cant get the old ones off!!!!!!!!! omg can ANYONE HELP!!!? i cut both nuts off the right bolt and i still cant get it off. someone sugested i drill threw it but i dont think that will work...and i cant cut threw the bushing either, i dont have new bushings and i hear u cant buy them. i dont have money to buy new LCA either, both sides are siezed. i have new KYB AGX and H & R springs waiting...what should i do?
Re: HELP, please lca bolts suck! (Ragezero76)
I would reccomend grinding off the head on the back one(one that faces to the rear), and getting a breaker bar and breaking off the nut that is welded to the front side, cut off the piece of the bolt that still remains, pry apart the bracket until you can get the lca out and take the lca to a shop and have them heat it with a torch and hammer the bolt out of the bushing sleeve. Get a new nut and use your new bolt. I have done it before Honda's are notorious for the bolts freezing in the bushings.
Re: HELP, please lca bolts suck! (IDriveHonda)
Actually, now that I look at the previous thread you posted about this, Ragezero76, just buying a new pair of control arms sounds like a pretty good idea. Find out where that guy got them from $86 or whatever on that last thread. Also call NAPA and see if they carry them. Parts.com is quoting $339.02 out of Pennsylvainia for a pair. Ack, but that's what I paid when I had this happen. It sucks.
Thanks,
Dougal
zelifcam
[Modified by zelifcam, 4:04 AM 10/21/2002]
Re: HELP, please lca bolts suck! (zelifcam)
It happened to me too...
It really sucks... I just ended up drilling it out after cutting off the shock mounts and the nut at the other side of the shock... It was not fun...
Good luck
Good luck
Re: HELP, please lca bolts suck! (DOHC-DX)
That happened on my buddies crx too, he ended up breakin both bolts on his lca's. Did you get the H&R sports or the races? If you got the sports let me know how you like them cause i was thinkin of goin with the sports and agx's pretty soon here too.
Re: HELP, please lca bolts suck! (AztecEJ)
That happened to my 95 civic. I broke the head off the bolt and I had to cut the shock fork to get the shock off. For this job, the angle grinder is your friend. Insdtead of getting a new bushing, i opted to just get new LCAs from an integra so I could mount a rear sway bar. Good luck.
