H22 EK Hasport Mounts - ANOTHER Axle Issue
Old Sep 17, 2012 | 07:58 PM
Mfoehrkolb's Avatar
Default H22 EK Hasport Mounts - ANOTHER Axle Issue
H22 Swapped EK
Hasport Mounts (Not Sure what exact model they are - IDK How to tell)
DA Passenger Side Axle
Yonaka Passenger Side Axle
I was always using DA axle set up with my car, when i had avid mounts installed. Since i switched to the hasport mounts, then i began to have a very... very slight vibration... It was bearable.
Now since i had LSD installed, the DA axle won't lock in... Even with C clip spread. So i bought a yonaka h22 swap axle for my chassis. The axle bind is outrageous and shakes horribly in between roughly 20-40 mph.
I have -1.2 Driver side camber, and -1.8 Passenger side camber.
Does anyone know how to tell the what model hasport mounts i have without removing them?
Cam someone tell me the axle length compressed for each hasport mount set up for passenger and driver's side axles?
How much axle should stick out of the hub when pushed in as far as possible?
Think the amount of camber could be the issue?
PLEASE DO NOT QUOTE MY FIRST INITIAL POST HERE
Old Sep 17, 2012 | 10:33 PM
deucedeuceEK's Avatar
Default Re: H22 EK Hasport Mounts - ANOTHER Axle Issue
Why did you change mounts? And I personally would front the money on some nice axles that would not have issues.
Old Sep 17, 2012 | 11:52 PM
Mfoehrkolb's Avatar
--- I parted out my old h22t hatch that was track only, and sold the DSS stage 3.9 axles with hubs, and decided to keep the hasport mounts because Avid did me dirty with a contest i won online and they decided not to honor it. Called them out multiple times and they made up lame excuses and then erases the comment all together. In a nut shell.
As for getting new axles, the yonaka are brand new. No reason to spend another 300$ on an identical but different branded axle. Any stage 1 h22 axle that companies provide are stock integra axles with the inner hub changed to the h22 one so it locks into the trans.
Old Sep 18, 2012 | 08:32 PM
Mfoehrkolb's Avatar
ttttttttttttttttt thoughts on my original post.
Old Sep 19, 2012 | 01:25 AM
dapimp1814's Avatar
The h22 in ek hasport mounts look like this
Old Sep 19, 2012 | 01:30 AM
Mfoehrkolb's Avatar
--- I know what they look like, but iirc they have 3 different models that move the motor around in various directions. IE. more drivers side space, more firewall space, and more passenger side space.
Old Sep 19, 2012 | 01:46 AM
dapimp1814's Avatar
My ek hatch is using the ^ mounts and hasport axles with vibration only when my rpm is 1k to 1.7k when rolling but im letting the wheels sit with stock height and no camber kits since the axle are only designed for that level. Maybe try changing the cambering.
Old Sep 19, 2012 | 01:54 AM
Mfoehrkolb's Avatar
--- funny that you say that about the camber kit...
Check out a thread I made a few hours ago about the came kit idea.
https://honda-tech.com/forums/showthread.php?p=47880082
Old Sep 19, 2012 | 02:12 AM
dapimp1814's Avatar
The 5mm outward might be your proablem becuz the axle would have more play due to not being more compressed causing the vibrating at the speed you mentioned.
Old Sep 19, 2012 | 11:18 AM
ESP.net's Avatar
90-93 Accord Midshaft, 88-89 Acura Integra Driver Side Axle, 88-89 Acura Integra Passenger side axle with Accord Inner Joint... 88-89 Axles are 1/2" shorter then DA, Everything else is the same... other then non ABS
Old Sep 19, 2012 | 08:44 PM
Mfoehrkolb's Avatar
--- DA axles are actually longer than a DC axle when compared side by side compressed. Believe me, i have done quite a bit of research on axles for this set up. I USED to run DA axles both sides, with DA inner with widened C clip and it was fine. Until qauife went in the transmission and it would no longer lock in.
Then instead of swapping the inner, i just bought a swap axle in order to "get the problem over with". Yet i am still back at square one... No more axle popping out with the LSD in and my expensive oem fluid draining on the ground, but still horrible shaking.
Old Sep 20, 2012 | 08:50 AM
THC07's Avatar
you should always buy your axles and mounts from the same company so that the geometry is always correct. mixing brand axles an mounts will cause issues 80% of the time.
Old Sep 20, 2012 | 09:32 AM
Hasport's Avatar
that is very good advice
Hasport's Avatar
post a picture of the mount kit you have and i will tell you what version it is
22"
with the car sitting on the ground. remove the axle nut. push the axle in as far as it will go. ideal length is flush with the hub. the axle can be in 1/4" or out 1/4" and still be within spec
super slammed cars contribute to the extreme axle angle and causes extra problems
Old Sep 20, 2012 | 10:44 AM
Mfoehrkolb's Avatar
--- Well after doing research, lots of people including a local car friend had no luck with hasport mounts and hasport axles combo. IIRC he ended up going DSS after speaking with them and they got him a set that worked.
Originally Posted by Hasport
post a picture of the mount kit you have and i will tell you what version it is. 22" with the car sitting on the ground. remove the axle nut. push the axle in as far as it will go. ideal length is flush with the hub. the axle can be in 1/4" or out 1/4" and still be within spec super slammed cars contribute to the extreme axle angle and causes extra problems
--- Please do not quote the pictures.
This is the only pictures i have available atm. If they aren't good enough, i'll get one later of the passenger side mount.
Also the current height of my car.
Old Sep 20, 2012 | 01:17 PM
the171's Avatar
might have to call QSD. Mixed with the HASPORT mounts... The setup problem free.
Old Sep 20, 2012 | 03:57 PM
Mfoehrkolb's Avatar
--- Since when does QSD make axles for my swap?
Old Sep 21, 2012 | 08:49 PM
yungmulacrx's Avatar
What transmission are you using cause iirc the m2b4 case is about 1 inch wider towards the passenger side of the car which could cause a problem.. Idk if that helps but thought i would throw that out there.
Old Sep 21, 2012 | 09:22 PM
Mfoehrkolb's Avatar
--- M2B4 is the only trans like that and it uses a different type of "lsd", it's completely different than the other non SH trans... No though, i am not M2B4.
that1s10
Nov 16, 2008 08:06 AM
ScottEK
Aug 23, 2006 04:58 AM
BOOST_92
Apr 27, 2006 02:58 PM
kaoss_11
Mar 3, 2006 09:13 PM
JSR
Jul 28, 2005 04:27 PM
