B series block questions.
Wondering whats the best block to go with sleeved to 84mm and gt28r turbo. Jdm GSR or LS?
Looking for witch one will hold about 350whp with no worries. Help be great thx guys.
if you will want to go bigger build it the correct way the first time. get a turbo with room to grow. and you dont need 84 mm to get 350 whp you can sleeve it with a 81 mm bore gives you room for mistakes.
b18b1 block 84mm bore Darton Sleeves
Stock LS Crank
Eagle H beam rods
Arias 9:5:1 Pistons
Cosmetic Head Gasket
Arp Head Studs
Gsr Head 3 angle valve job and port and polish
b16b cams
Garret 35r
jg intake mani
this is what im thinkin so far
Stock LS Crank
Eagle H beam rods
Arias 9:5:1 Pistons
Arp Head Studs
b16b cams
Garret 35r
jg intake mani
sounds better you still need fuel system, clutch, and i maybe forgetting some stuff i think 300-350 is a good goal learn how to drive that car. then work on traction such as tires, lsd, and traction bar.
Who is Mr Robot?
also skip the b16 cams, pick up a set of gsr cams... the poor mans type r cam
and are you planning on making more power? if not, a 35r is overkill
okay it between 35r and 28r. I was thinking GSR cams as well. Good point on the over kill for 35r. Not to sure this is my first turbo build so... just trying get everything on point.
Aem fuel Rail/FPR
Rc 550
Walboro 255
Not sure witch clutch imma go with yet. Any advice for 350-450whp?
Aem fuel Rail/FPR
Rc 550
Walboro 255
Who is Mr Robot?
competition clutch stage 5 has never steered me wrong
but you won't make 450 on a gt28r... and theres a big gap between the 2
figure out exactly what you want to do then decide on a turbo
