any tips on setting launch control s300 d16t
running a d16 vitara motor. trying to set lc(launch control) to build some boost off the line. i have it set to
-15 timing +15 fuel at 4500rpm but no boost
i dont know really what to do without blowing my motor. any insight would help.
should i use more timing less fuel or less timing more fuel.
Make sure your activation rpm is around 500-300 rpms lower then your launch limiter rpm.
Try -25 ignition and 40 for fuel.
Experiment with rpm, retard & fuel values until you achieve the launch you are looking for.
whats a good value to start with it? i want to set mine up as well, just need a low value to start with kind of like how i set my boost solenoid
1000cc
t3/t4 garrett 57 trim 63 ar
ramhorn
just a little info
thanks mtber for the info. now without a egt gauge to moniter exhaust temp how should i go about doing this safely wihtout blowing my turbine to peices. im assuming the afr will go full lean
I think the A\F will go full rich. Haven't messed with mine but I have mine setup the same as mtber.
hondata states to type - first i beileve. i forget what mine was set to
Pippen_001
Jul 26, 2007 01:24 PM
