Turbo b16 put back to n/a
I have a b16 del sol with turbo kit running 440rc injectors and a walbro fuel pump
I was wondering if I could take off the kit and keep the injectors and fuel pump in and set the hondata back to jdm tune, would it be fine?
It does have the stock fpr and motor is stock
those injectors are to much for a stock motor, besides you will need a new tune! best option is to put back the oem injectors and fuel pump and use the stock oem ecu! set the timing back and the motor should run great! no tune needed!
the pump can stay, it wouldnt affect anything with an oem regulator/injectors etc.
But I would def put the stock 240cc injectors back in and rn a stock ecu
Or are you intending on running a chipped ecu and making your own tunes???
he said hondata. he is probably talking about the base map for the "jdm" b16. to the op, I wouldn't go off the base map, because if you look ,the fuel and ign. maps are all out of whack.
Base maps always have room for improvement both in power and drivability. If your plans are to stay naturally aspirated for some time, even with your stock B16, it would be wise just invest to have it retuned.
Out of every "game"
Mar 17, 2006 11:23 AM
Vp Special K
Jul 18, 2005 11:52 AM
Teluan
Aug 29, 2001 09:04 PM
