450cc injectors+walbro 255 fuel pump and stock ecu?
trying to get my car down to jeff evans for tuning but i live about 4 hours away. I know it would be a better idea running the stock injectors with the stock ecu, but id rather spend my time with jeff tuning and not installing fuel injectors and so on. Theres also a booked schedule so it would give me some time to make sure nothing is leaking and such before i go tuning. Would it be OK if i installed my walbro 255 fuel pump and tuner toys 450 injectors and just turn the fuel presure down with my aeromotive fpr?
Re: 450cc injectors+walbro 255 fuel pump and stock ecu? (dc2legend)
installing injectors takes 20 minutes at most. I'd say drive down stock and get there an hour early and install when you are there. Practice installing them now so you can do it fairly quickly and will have no trouble once you are there. Teh only problem I am seeing is the resistor box you will need. Make sure it's ready to go. Is your ECU chipped already? You could run a base map to his place. GL
Re: 450cc injectors+walbro 255 fuel pump and stock ecu? (adseguy)
fuel pump will be fine, but your car won't run for **** with the 450s + stock ecu. if it *does* run, you'll be dumping so much fuel you may wash the rings... leave the injectors out.
EG-B20vtec
11-17-2006 10:47 AM
jeremy.
09-29-2003 05:35 PM
