new jdm swap burning antifreeze
Old Oct 15, 2002 | 06:44 PM
ekhatchhybrid's Avatar
Default new jdm swap burning antifreeze
it only does it periodicly not constantly it only burns it every now and then, i got the motor form jdmhondaparts.com (NEVER PURCHASE ANYTHING FROM THEM) and it ran cool for a while but maybe it burned to much and it started getting really hot so i parked it and i dont know what it could be any suggestions ??? i hope it isnt a blown head gasket please somebody help me out
Old Oct 15, 2002 | 07:40 PM
teg92's Avatar
Default Re: new jdm swap burning antifreeze (ekhatchhybrid)
Sorry all the signs sound like internal failure. Does your oil look milky or does your coolant of oil in it?
Old Oct 15, 2002 | 09:22 PM
Nameless RB26's Avatar
Default Re: new jdm swap burning antifreeze (teg92)
Is it leaking at all? Or is it actually burning?
Old Oct 15, 2002 | 10:24 PM
SlowWhiteEvo's Avatar
Default Re: new jdm swap burning antifreeze (Nameless)
did it suck your overflow bottle dry? there is probably just an air pocket in the cooling system since you just got your swap. It will eventually purge the air if you keep refilling the overflow bottle. Give it a week or so. Mine did the same thing
Old Oct 15, 2002 | 11:01 PM
Tofurky's Avatar
how long ago did you do the swap? have you tried flushing the coolant completely, and refilling...
if you don't see oil or any residue in your coolant, try refilling, like stated before it could be the air pockets. but if it continues to do this after a week. it just might be your head gasket...
what radiator are you using? i'm having similiar problems, my cars been running so so and runs very hot going uphill on freeways. i'm hoping it's since i'm using the stock cx radiator...
Old Oct 16, 2002 | 01:08 AM
tonyxcom's Avatar
Default Re: new jdm swap burning antifreeze (Ruckus138)
yeah, either you didnt fill up your radiator correctly and you are still purging air, or you have a blown headgasket.
david45249
Honda Civic (2001 - 2005)
20
May 24, 2011 04:13 PM
xTomei
51
Aug 31, 2010 08:32 AM
ramonjones16
Sep 1, 2009 10:20 AM
SoHc94
Sep 7, 2006 12:12 PM
Hatchd
Sep 19, 2003 12:51 PM
