civic LS swap
civic LS swap
Car recently started over heating...I checked coolant its a a good level theres no leaking but it seems like the coolant is leaking somewhere because everytime i drive somewhere the level of coolant gets lower....I dont think its a blown head gasket because the oil is still golden there is no antifreeze mixed with it...Im not blowin white smoke...I dunno what is going on any help???
Re: civic LS swap
Just off hand, sounds like the system wasn't burped to get all the air out. There is a bleeder bolt on the thermostat side if I remember right that you loosen and let it release coolant until no more air bubbles appear.
New User
Re: civic LS swap
Re: civic LS swap
Burping the system I just run the car with radiator cap off right. Is the bleeder bolt on the front of the block. Because its not in the same location as my D16Z6. I was told to run the car radiator open and then turn on the heat to get rid of all of the air.
DjBij099
11
04-13-2008 11:38 AM
