Turbo flange bolts falling WTF
Old Jul 30, 2012 | 08:07 PM
rico892002's Avatar
Default Turbo flange bolts falling WTF
hey what are you guys using to to connect your turbos to the manifold..im tired of mines backing out and the turbo damn near falling off..Ive tried different methods but havent been successful with anything thanks
Old Jul 30, 2012 | 08:12 PM
Aradin's Avatar
Premium Member
Default Re: Turbo flange bolts falling WTF
Lock washers.
Old Jul 30, 2012 | 08:29 PM
Hyper16-Johnny's Avatar
Originally Posted by Aradin
Lock washers.
x2, and if it'll make you feel better, "Loctite."
Old Jul 30, 2012 | 09:05 PM
EsotericImage's Avatar
Retired Moderator
I think spoolin or go autoworks has copper lock nuts that work quite well..
If those dont work, your next step is Stage 8 locking fasteners
Old Jul 31, 2012 | 05:10 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
How do you think you are supposed to properly remove a "Loctite"d fastener? With heat... Soo, that idea won't work. Yikes.
Old Jul 31, 2012 | 05:14 AM
rudebwoy's Avatar
studs, topmount manifold. LOL
Old Jul 31, 2012 | 05:54 AM
Muckman's Avatar
Moderator in Chief
Lock washers or serrated nuts. I use grade 10.9 fasteners and torque them. M10 to 40 ft-lbs. M12 to 60ft-lbs.
Old Jul 31, 2012 | 08:27 AM
4genaccordfreak's Avatar
Either:
ARP 3/8"-16 stainless bolts with red loctite.
or
High-strength studs and nuts with red loctite.
I am currently running Full-race studs and nuts on my setup with no loctite, I even have anti-seize on the section of threads that are in the manifold flange.
no issues or leaks.
best advice is to check the bolts and/or studs after 3-4 heat cycles and re-torque if necessary.
Old Jul 31, 2012 | 10:30 AM
rudebwoy's Avatar
I hate to say it, but the full-race studs sucks heat and vibration from solid mount snapped mines I guess, I am currently using ARP exhaust studs.
Old Jul 31, 2012 | 05:36 PM
2point2's Avatar
I've always wanted to try this on manifold/turbo bolts. I've done this on roller coaster brake systems with special tools but I can be done with basic pair of pliers. You'll find videos on youtube on how to do this.
Not sure if the heat will anneal the safety wire though.
Whatever you decide to do, buy high grade made-in-the-usa hardware.
Old Jul 31, 2012 | 06:35 PM
rico892002's Avatar
thanks guys might just use good old lock washers and bolts hopefully this fix my problem
Old Jul 31, 2012 | 08:02 PM
SpeedOFsmell's Avatar
Always had a lot of trouble with my bolts walking out over time as well. Never used lock washers though. Crappy ebay manifold inhibited my ability to fit much in there. I used to just check the bolts once a week since I was always fiddlin' around with somethin anyway.
Buy good parts!
Old Aug 1, 2012 | 07:15 AM
TKERacer619's Avatar
ATP studs and locknuts. A lock washer isn't going to do anything and neither is loctite. The heat just relaxes them. You would need a star washer and proper nuts if you were going to try that route and the nuts are usually rather large.
IF it works with lock washers and loctite it would have worked without them.
Old Aug 1, 2012 | 12:18 PM
4cylfiend's Avatar
Lock washers will work perfectly brother.
Old Aug 1, 2012 | 06:05 PM
whited's Avatar
CRX God
We used these on exhaust of racing carts. You had to because you had a restricter plate bolted between the engine and the exhaust. The officials would crimp your wire with a special tag to make sure you didn't remove the plate in between races. There where different plates for different classes.
Old Aug 2, 2012 | 05:11 AM
BigMike0147's Avatar
This guy speaks the truth. I have lock washers on mine, but if you ever take them off after plenty of heat cycles, you'll see that they are completely flat.
Old Aug 2, 2012 | 07:26 AM
LS AzZkIkr's Avatar
http://www.treadstoneperformance.com...nd+Gasket+Kit+
Sprockets
Dec 4, 2011 07:15 PM
oodie
Aug 20, 2009 10:54 PM
BDogggUT34
Apr 3, 2007 07:41 AM
Mario.
Feb 1, 2005 06:02 PM
swlabhot
Apr 29, 2003 08:19 AM
