Bolts, Nuts, Gaskets, Flanges
Where is the best place to get these things? Building my own setup... the last setup I had I used Ace for some of the things, but my friend had most the rest. Just simple things -- bolts to connect the turbo to the mani, gaskets to go inbetween, flanges for the downpipe. Basic necessity's. Thanks !!
**** that, if the mating surface of your turbo and mani are true and straight, just cut out a coke can, takes the heat, easily plyable so it fills the cracks and you can have a multi functional can, first drink the pop then take 4 min to cut it out then recycle the leftovers lol
yeah, if the surfaces are machined straight, gaskets will not be needed
try to get some grade 8 nuts and bolts, with lock washers
all the sites that rainman suggested are pretty good sites
91_civicsi
May 12, 2008 11:57 PM
