wastegate for silver surfer
im sure a standard 38mm (or mvs) would work fine. the spring just determines the minimum boost level. most likely you will want to get a boost controller to turn it up to the desired level to reach your hp goal.
what manifold are you using? what wg flange does it have?
psi and bar are just different units of the same measurement. 1bar = 14.5psi
do you plan to use a boost controller or are you trying to achieve the desired boost pressure with just the wg spring pressure?
the highest single spring you can get is .9 bar (13.05psi). after that you need to start using multiple springs to achieve higher psi
spring pressure chart
http://www.tialmedia.com/documents/w3_tial_44_sp.pdf
