GE sandwich adapter loosing seal at the block
So I installed the unit, and have been waiting to start the car till now. In the time it took to prime the car's oil pressure, the damn thing sprung a leak. I don't mean a little leak, I mean about a quart in 30 seconds. A bad leak. So I pulled it off, wiped it down really well, along with the block. So this time, just be sure, I used a very thin film of RTV on the blocks surface. This time, it took about 10-20 seconds of priming, it sprung the same leak. It is spraying oil all the way up, down and around the damn block! I am having trouble getting ahold of GE, but need this car running. Is there a place I can get a new o-ring? Like in town possibly? Or could there be something wrong with the way I installed it? Maybe I need an entirely new adapter? Help with your experience please!
it might be possible that it was over tightened and the o-ring behind the oil filter mounting plate was torn, that's what happened to a customers h22, it shot out oil. It's kinda hard to explain but there is a small o-ring behind the actual mounting surface of the oil filter. check it out.
Goodluck.
Goodluck.
I mean, RTV works fine, as long as you use it correctly. My downpipe gasket is made of RTV because no one local had the correct sized gasket. You just have to follow the directions and let it set up correctly before you go putting pressure behind it.
It was the gasket on the adapter itself, GE got me one really quick, and works fine now. Apparently they the ones they use aren't very high quality, and actually have quite a bit of memory. Over tightened it, and that's all it took. Thanks though guys!
92integraVTECgsr
Sep 30, 2008 04:00 PM
MeanGreenEG9
Jan 13, 2003 01:40 PM
