turboed ls hatch, stalling help
I have a eg hatch with a b18b motor bone stock with a turbo kit on 8 pounds. tial waste gate hks bov, 2.5 inch icp, log manifold and presion 60-1 turbo and 440 injectors. the car starts and idles prefectly at 750 rpms but when im driving the car and i put it in nutural the car will stall out. for example if im coming to a red light and im in 4th gear i will put the car in nutural and the rpms will drop and the car will stall out. this all started 1 day when i drove my car to work and i unpluged the ecu and than when i came out of work i plugged it back in and i started to drive home and when ever i would go to stop the car it would stall. i am using a p72 ecu that is chipped with chrome and the car was also tuned on chrome. i think my tune must have erased itself??? i have checked for vacuum leaks and cleaned my iacv but no luck.
Originally Posted by H22*CiViC
but if the iacv was bad than the car would have a bouncing idle corret?
Idle set screw on the throttlebody is set way to low. Adjust it some so the car idles when unplug the IACV and then adjust it to the correct rpm then plug iacv back in
ok i will try to adjust the base idle tomorrow and i will update. the only funny part is it all started after i unpluged the ecu.
SnailedEG
Sep 15, 2010 03:43 PM
jdmhondaes1
Jul 25, 2010 11:48 PM
