y7 trans on y8 engine?
Old Jun 27, 2012 | 06:36 PM
ej6kid's Avatar
Default y7 trans on y8 engine?
I have two cars. An automatic 98 ex and a manual 98 civic dx. I am looking to swap the y7 5 spd to my coupe and the y8 auto to my dx. I have been searching for write ups or any info, nothing quite straight forward with an answer. Is this do-able with all the parts from car to car?
Old Jun 27, 2012 | 06:41 PM
ej6kid's Avatar
Default Re: y7 trans on y8 engine?
Forgot to ad..I know y7 trans' arent the best when you compare them to others. Just looking to make it 5 speed no performance mods here so
Old Jun 27, 2012 | 06:43 PM
94EG8's Avatar
Seagull Management
The Y7 trans will work fine on the Y8 engine. The Y8 auto trans worn work right on the Y7 engine though, you'll get a P0715 code dude to a different 3rd gear ratio and it'll shift a little weird.
Old Jun 27, 2012 | 06:44 PM
jbpnoman's Avatar
Putting the manual transmission in the auto car should be fairly simple, and there are dozens of write-ups. Just search.
Putting the auto in the manual might be a bit more tricky, but I think there's a conversation about it somewhere. Once again, just search.
Old Jun 27, 2012 | 07:38 PM
ej6kid's Avatar
The code Ill get on the automatic car will cause it to shift weird..just in 3rd? or through all gears? Is it bad to have that then? I dont have a check engine light, the car will be used as an automatic beater after this. I've been searching for this swap for a day or two. Im getting all different answers everywhere. Thanks for the info guys!
Old Jun 28, 2012 | 03:26 AM
94EG8's Avatar
Seagull Management
It will shift a bit weird in all gears. Also you need to swap the engine and cabin harnesses in both cars. Swapping the cabin harness involves pulling the interior including the dash out of both cars (you can modify the automatic harness to work with a manual transmission, but you really need the automatic harness for an automatic transmission)
84dime
Dec 15, 2010 07:36 AM
roachsboosted16
Apr 22, 2008 07:21 AM
03akkord5spd
Feb 21, 2007 10:07 PM
exare250
11
Oct 23, 2004 07:04 PM
