possible head gasket problem?
Old Jun 22, 2012 | 10:45 AM
efstunnin's Avatar
Default possible head gasket problem?
ok so my homie bought a 97 ek coupe
it has a built b16 and ****
but recently it started loosing all the oil and its not leaking and the water in the radiator keeps depleting
im thinking its the head gasket because its not leaking any fluid or any oil
if anyone has any thoughts on it please lemme know
thanks guys
grumblemarc's Avatar
The Grumpiest
Default Re: possible head gasket problem?
Do a compression and leakdown test.
Old Jun 22, 2012 | 10:49 AM
Dc4LsTeG's Avatar
EK9
X2
/thread
Old Jun 22, 2012 | 10:51 AM
efstunnin's Avatar
is there anywhere i can get the tool for the leakdown cause i dont have one?
Old Jun 22, 2012 | 10:53 AM
Dc4LsTeG's Avatar
EK9
AutoZone
Old Jun 22, 2012 | 10:54 AM
The Grumpiest
You can have a shop run these tests as well.
Old Jun 22, 2012 | 10:56 AM
efstunnin's Avatar
dope ill try those right now and see whats up
Old Jun 22, 2012 | 11:04 AM
JAYROE's Avatar
I am having a simular problem with my R motor. The water tube on the back of the block can leak without seeing any on the ground.
Old Jun 22, 2012 | 11:06 AM
efstunnin's Avatar
alright..ill chaeck that also thanks
does your oil also dissapear?
Old Jun 22, 2012 | 11:12 AM
The Grumpiest
I'm betting it doesn't. The problems you're having are NOT similar.
Old Jun 22, 2012 | 11:14 AM
efstunnin's Avatar
alright..cause itll be good for like a day or two..then all of a sudden itll start to overheat and we check the water and its gone..but the oil is still good just a lil low..
Old Jun 22, 2012 | 11:22 AM
The Grumpiest
If you're not leaking coolant, you're burning it.
Old Jun 22, 2012 | 04:47 PM
JAYROE's Avatar
Yea actually the oil does dissapear. But only if i am running it hard. I am wondering if the neck on the back allows air to enter the coolant system and pressurizes things. Not tryin to be a know it all. Just a honda lovin redneck from the woods in texas.
Old Jun 22, 2012 | 04:59 PM
The Grumpiest
Even if it were leaking it would not draw air in to pressurize. There is no vacuum happening in the coolant system. Doesn't work like that.
Old Jun 22, 2012 | 05:31 PM
JAYROE's Avatar
Hmmm. Well when we build high rises down here in texas i have seen chiller lines for condensors get leaks and suck in air. It all depends on the location of the leak and fluid levels. This is how i am basing my thought process.
01_civic
Classic Hondas
Jun 3, 2012 06:58 PM
moosta936
Mar 4, 2007 04:14 PM
BluLude
Jul 22, 2005 06:20 AM
preludeguy_92
May 23, 2005 06:39 PM
Trellis
Sep 18, 2004 07:58 PM
