Overheating issues.
Old Mar 4, 2007 | 01:38 PM
moosta936's Avatar
Default Overheating issues.
okay well, i changed my thermostat, which i heard was a common overheating problem for acuras. after i did that the overheating seemed to go away and everything was all peachy. Until yesterday...i changed all my radiator and heater hoses, and suddenly it reoccurs. it happened after i sprayed my engine bay on base. Any clues as to what the problem is? please help this overheating issue is killing me.
Old Mar 4, 2007 | 01:59 PM
racerjohn's Avatar
Default Re: Overheating issues. (moosta936)
maybe a head gasket
Old Mar 4, 2007 | 02:14 PM
moosta936's Avatar
how much would that be to replace? and if i were to replace it and the problem was still present any other ideas of what it could be? like what all things could cause over heating?
Old Mar 4, 2007 | 02:23 PM
racerjohn's Avatar
Default Re: (moosta936)
depends if your gona do it yourself or not i was told 250 plus a head gasket but i have heard numbers all over the board as well all the way up tp 800 . If it isnt the head gasket im not exactly sure. Your not leaking fluid are u, have u done a leak down test
Old Mar 4, 2007 | 02:29 PM
moosta936's Avatar
well yea, a small leak coming from my header...so sounds like that's probably it then huh? is a head gasket hard to change yourself?
Old Mar 4, 2007 | 02:53 PM
racerjohn's Avatar
umm that depends u should have your head resurfaced if u do it. I have done mine 2 times but its not very fun at all. My opinion take it somewhere and have them do it but if u do decide to do it your self im sure u can find a write up somewhere on here. Everytime ive done it a bolt breaks somewhere and it goes all down hill from there.
Old Mar 4, 2007 | 02:56 PM
moosta936's Avatar
deamn mann....sounds like fun.
Old Mar 4, 2007 | 02:59 PM
Dealer Leaf's Avatar
Did you properly bleed the coolant system?
Modified by Dealer Leaf at 4:19 PM 3/4/2007
Old Mar 4, 2007 | 03:04 PM
moosta936's Avatar
oh ****...i don't think i did. how am i supposed to do that?
Old Mar 4, 2007 | 03:21 PM
Fill your radiator full while the car is cold, Leave the rad cap off and turn the car on. Let it warm up. You should see air bumbles come up threw the top of the rad and the fluid level drop.
To know if the therostat is open feel the top rad hose it should be much hotter than the lower one. When there both the same temp or near the same the thermostat is open. Add fluid as the bubbles come up.
when you think all the bubbles are gone and the rad is topped off, put the rad cap back on and then shut off the car and your done.
NOTE: it may take time before you see air bubbles you are waiting for the thermostat to open
Modified by Dealer Leaf at 7:51 PM 3/4/2007
Old Mar 4, 2007 | 04:14 PM
integra8804's Avatar
if u supspect a blown headgasket, do a compression check first
rajah99
Honda CR-V & Element
11
Jan 23, 2012 09:49 AM
g0tsilkk
Oct 16, 2006 11:48 AM
eg6madness
Aug 17, 2006 08:45 PM
djnickles
Sep 4, 2005 01:33 PM
ALMXDUPINTEGRA
May 11, 2005 11:05 AM
