92 EG Idle problem
Old Jun 16, 2012 | 07:39 PM
Tinoo's Avatar
Default 92 EG Idle problem
Hey everyone, Im having an issue here.
I have a 1992 EG hatch with a 99' GSR swap.
I've just done a Skunk2 Intake Manifold swap along with a 68mm Omni TB.
I have all the plugs plugged into the right sensors, all lines everything connected.
I am using OEM gaskets for the manifold and the Omni gasket for the TB that came with.
I've adjust the new Omni TPS to the same v as my old TPS.
my issue is; when I start the car, its starts but Idles very low, maybe about 3-500, and the motor tends to shake.
Anyone have any idea what could be the problem? It would be much appreciated!
Old Jun 16, 2012 | 07:42 PM
Former User's Avatar
Default Re: 92 EG Idle problem
CEL codes?
Does the engine idle to spec when warm?
Does you engine have an FITV?
Have you cleaned the IACV?
Old Jun 16, 2012 | 07:50 PM
Tinoo's Avatar
no CEL.
once i start the car with the OMNI TB, it idles low at start. but if I put the stock gsr TB back on with the stock TPS it idles just fine like it should
Old Jun 16, 2012 | 07:53 PM
Tinoo's Avatar
and no FITV.
Old Jun 16, 2012 | 09:32 PM
Tinoo's Avatar
noone ran into this problem before?
Old Jun 17, 2012 | 07:51 AM
Tinoo's Avatar
bumppp, need answers
Old Jun 17, 2012 | 01:15 PM
Tinoo's Avatar
noone has a clue? im pretty much stuck and just about to give up and leave that stock one on
Old Jun 17, 2012 | 01:24 PM
grumblemarc's Avatar
The Grumpiest
Originally Posted by Tinoo
no CEL.
You answered your own question right here. You can't start putting all these air/fuel altering parts on the engine and not get it tuned to make use of and operate properly.
Old Jun 17, 2012 | 06:05 PM
Tinoo's Avatar
My buddy has the same set up with a blox manifold and his ran perfectly fine untuned.
Old Jun 17, 2012 | 06:07 PM
The Grumpiest
So you say. But... 1) we're not talking about your buddy's car and 2) how do you explain why it only runs correctly with the stock throttle body?
Maybe you should talk to your buddy and see where you're going wrong. But If the manifold was different, then it's not the "same" setup is it?
And aren't you supposed to install the OEM TPS on the Omni TB?
Old Jun 17, 2012 | 07:08 PM
Tinoo's Avatar
theyre all ITR reps.
The omni came with a new TPS . I'm guessing i need to adjust the Idle screw. imma try that tomorrow.
Old Jun 17, 2012 | 07:30 PM
villc713's Avatar
You answered your own question bro
Old Jun 17, 2012 | 08:46 PM
Tinoo's Avatar
Your saying I have to get a tune to be able to run my 68mm TB ?
ferio_11
Dec 2, 2017 05:14 AM
DanInOttawa
Aug 21, 2014 06:59 PM
michaelsej1
18
Feb 21, 2011 07:13 AM
gsrboost737
Oct 25, 2010 05:16 PM
Cigarbufff
Jan 2, 2006 04:42 AM
