Ebay Turbo Questions!
Hello, I'm a noob and need help for my plans... I'm planning on building a honda civic or any type of honda with a D15 or D16 engine. Here is a link on a Ebay Turbo kit, not sure if it needs customising or direct bolt on? If it will fit all honda d15 or d16? http://www.ebay.com/itm/260777549102...ht_2814wt_1195 I know this thread maybe open before, please I want too build a nice honda
that question right there shows you're not ready for boost. you havent even researched the different quality kits available nor have you stated a budget or power goal.
i predict if you ever do go through with this it's gonna cost you a lot of money that didnt need to be spent.
The cheapest kit I have seen that is decent is the Treadstone kit. Even if you buy it for $1,700.00 you are still a couple of grand away from having a reliable set-up.
I'd stay away from eBay turbo kits. Will they work? Yes. Will they last? No. In the end you'll be re-purchasing parts.
The best advice I can offer is to start reading as much as you can about turbo setups. For the most part everything is straight forward. Determine a HP goal and work backwards.
If you want a quality kit check out the kit offered by SpeedFactory.
http://www.speedfactoryracing.net/st...roduct=1650783
The EASIEST way to do it is to find a build with the power goal and budget you want to be at and copy it part for part. After that, find a good tuner.
Civiclx
Jan 23, 2008 07:32 PM
ProjectEG8
Feb 15, 2007 09:47 PM
